Camera Connection Kit Problem
This is a discussion on Camera Connection Kit Problem within the iPad Help forums, part of the Apple iPad Discussions category; I have a new iPad 2 and am really enjoying the iPad experience. However, I am having a problem importing “JPG” pictures from the SD ...
Results 1 to 7 of 7
    49826
    Florida
    I have a new iPad 2 and am really enjoying the iPad experience. However, I am having a problem importing “JPG” pictures from the SD Card reader purchased with the “Camera Connection Kit”. The pictures work OK on the SD Card interfaced to my PC. I am following the instructions exactly as explained (Lock the iPad, insert the SD Card Reader, insert the SD Card in the Card Reader, Unlock the iPad). Nothing happens on the iPad (it just opens to the home screen). I have saved some photos from e-mails and with the Sony Cybershot interfaced directly to the USB Adapter that comes with the “Camera Connection Kit”. Further, I can view those photos. However I cannot successfully import photos via the SD Card Reader. I visited an Apple Retail Store and had them check it out. My SD Card reader purchased with the “Camera Connection Kit” worked with their SD Flash card, but not with my two. I had them format my SD card and import one of their photos to it so I could try that particular SD Card in my SD card reader. No luck with my iPad 2. They suggested I purchase a new SD Flash Card. I did. I purchased 2 Sony SD Cards and have the same results (do not work). Question, has any one else experienced this? Does any one have any suggestions? Is there a particular MFG SD Flash card that needs to be used? Or, perhaps, the SD Flash card need to be formatted a special way?
    By the way, I have two calls into the Apple Support Line and have been waiting for a call back for 10 days. Thanks, Richard
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    I have 2 32GB play.com branded SD cards, both of which work fine in the photos app and with iFile (jailbroken) iPad1.
    Ensure your card is formatted on FAT/FAT32. Don't know what else to suggest. Sorry.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    iPad Guru
    30446
    12 times
    3,196
    What filenames do the images have?
    The photos app is really picky and will only except IMG_1234.jpg images, where 1234 can be any number.
    21158
    Nov 2010
    Texas USA
    23
    Try making a /DCIM directory on the card and put the .jpeg in it.
    49063
    109
    So you're having trouble viewing photos that you've copied from the PC to the SD? And SD cards coming straight from other cameras work ok?
    The SD card needs to be structured as if it's coming straight from the camera so the photos need to be in a folder called "DCIM" and follow the naming convention "IMG_1234.jpg".
    If you just load files into the root of the card, or have renamed them to something more personal then they won't display on the card.
    iPad Guru
    30446
    12 times
    3,196
    Just for the sake of organization.
    OP has another thread open regarding the exact same question. It would be easier, if we keep all communication inside that thread, instead of splitting it into two.
    119 times
    15,248
    It's done..thanks for spotting this, DontUnderstandMyIpad
  1. Camera Connection Kit Problem
    By RTFREY in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 12-11-2010, 07:47 AM
  2. Replies: 3
  3. Camera Connection Kit with Panasonic LX3 Digital Camera
    By Atwell in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-23-2010, 08:35 AM
  4. Problem with Flip HD and camera connection
    By Mikeb41g in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-18-2010, 10:42 PM
apple ipad camera connection kit problems
apple sd card reader for ipad not working no photo to import
camera connection kit sd problem
create dcim folder sony cybershot for ipad
i pad wont accept pictures from card reader
ipad camera sd card reader no photos to import
ipad card reader no photos to import
ipad no photos to import
ipad sd card reader no photos to import
sd card reader says no photos to import
