no sound with speakers, only earphones
This is a discussion on no sound with speakers, only earphones within the iPad Help forums, part of the Apple iPad Discussions category; as the topic says, i got no sound with my speakers on my ipad,only when i plug in my earphones i got sound. when i ...
1Likes
iPad Enthusiast!
as the topic says, i got no sound with my speakers on my ipad,only when i plug in my earphones i got sound. when i also try to adjust the volum settings on the right side of the ipad, it says earphones even when my earphones is not pluged in.
It sounds like my ipad has locked the sound so it only works with earphones/headsets.
i have tried to reboot it, but its still the same problem. Is there anything in the settings i have to do to unlock this?
04-28-2011 06:44 AM
Originally Posted by
Blu3Moon
OK - this definitely sounds like a faulty earphone plug - i.e. one that's detecting an earphone even though there isn't one plugged in....but let's just try some lateral thinking....
(a) is the iPad in a dock or is it plugged into the charger? If so, remove it from the dock or unplug the charger and try again. We've had a case recently of a faulty charger/dock plug that convinces the iPad it's connected to a headset.
(b) is it paired with a Bluetooth headset that's possibly in range?
OK - probably these are not going to work, but it's probably worth a try.
iPad Enthusiast!
Tim SPRACKLEN
its not plugged into a charger now. All this happened today when i woke up. I had the ipad plugged in to the charger this night before i went to sleep. I also used the earphones with my ipad before i went to bed and charged it. The bluetooth is off. But a weird thing is when i go to the settings and sound settings and i try to adjust the volume there, the sound come, also when i try to change the ringetones. But it wont work on youtube, safari or ipod. And again it says earphones when i try to adjust the sound bar on the right of the ipad when the earphones is not plugged in....
One thing to mention is that i sometimes lock the ipad to landscape. Can that affect the sound output? Cause i locked the ipad yesterday having the earphones plugged in before i charged it
Blu3Moon
Tim SPRACKLEN
What version of iOS are you running. As you know, in iOS 4.3 and beyond they made it possible to re-assign the function of the mute switch, which in iOS 4.2 had been fixed as the switch next to the volume control. In 4.3 it is possible in 'Settings' to change the function of that switch from Mute to Orientation Lock and back. Maybe you've got it set to Mute? Double-tap the Home button to open up the multi-task bar, flick the screen to the right and, at the far left - adjacent to the iPod controls (N.B. iPod not iPad) - will be the other control - i.e. this control can do either mute or orientation lock and it swaps with the physical mute switch next to the volume control.
But it doesn't sound like this is the problem, because you get that Headphone indication when you try to change the volume and that certainly means the iPad 'thinks' there's a headset plugged in.
You say you've power recycled the iPad - i.e. pressed and held the Power switch until the slider control appears, accepted the offer to shut down, waited until the screen was completely blank and then powered on again.
I can't recall now, but there's one last thing to try - and that's a reboot. With the iPad switched off, press and hold the Power and Home buttons simultaneously until the white Apple logo appears. This can take quite a time - about 15 seconds, but it will eventually....
The iPad will then reboot - again it takes some time. Then try again and see what happens....
Good Luck and let us know - we'll crack this yet!!
iPad Guru
Have you tried turning up the volume when the earphones are unplugged. iOS has separate volume memory for both states, so you can have volume set to zero with no headphones than crank to full blast when you plug in headphones.
gentlefury
Great suggestion!! Thanks - Tim goes off and hides again....
iPad Enthusiast!
I am using the latest version of iOS 4.3.2. I got my Ipad 2 last monday. I know that i can change the switch on the right side to either mute or orientation lock and not on mute.
Ive also tried to shut it down several times with no effect.
But i tried the last advice u suggested - switched the ipad off and then press and hold the power and home buttons at the same time. The Ipad came back to life and i tried to watch a video on youtube. I got like 10 secs sound from the speakers then suddenly it got muted. I also tried to adjust the volum by the bars on the right side when i got sound from the speakers and it didnt said earphones, it actually came sound out of the speaker.Then suddenly it became mute again after 10 sec while watching the video. And when i tried to adjust the volum it saids earphones again.
so weird, but anyways got to go work. Seems like the problem is no 100% solved yet... but im going to give u a feedback later this day. thx for the help.
Blu3Moon
This is most definitely weird. OK - well this last test proves it's not a problem with the headphone plug, as I'd first suspected. Do you have any other apps that have an audio output? Say Internet Radio or some music in the iPod app? I'm wondering now if it's an app issue? But you can see I'm 'clutching at straws' and running out of ideas before suggesting you return it to the store...
iPad Enthusiast!
gentlefury
Have tried that with no effect.
One thing to mention again is that when i got sound with earphones and switch to mute on the right side of the ipad, the slide thing. When i try to slide down ( mute) the sound doesnt get muted at all but i get the picture on the screen that its muted.... Well this was my last post for now. Giving you feedbacks later.
Blu3Moon
gentlefury
The Mute switch should only mute 'system sounds' and not app sounds - so, for example, it mutes the 'new email' and 'keyboard clicks'. It's intended to avoid the embarrassment of your iPad playing the new mail sound in the middle of a business meeting or at night (because that new mail sound will still come out of the iPad even if it's in Sleep).
Good Luck
- You may not post replies
- You may not edit your posts
Forum Rules
By Luvntravln in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 05-06-2011, 03:53 PM
By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 03-06-2011, 11:16 AM
By J_mccasland in forum iPad Help
Last Post: 03-01-2011, 12:19 AM
By rroboh in forum iPad Help
Last Post: 11-19-2010, 12:32 AM
By padmeup in forum iPad General Discussions
Last Post: 09-10-2010, 09:08 PM
ipad 2 sound only through headphones
ipad 2 sound only works with headphones
ipad no sound from speaker
ipad no sound speaker
ipad only plays sound through headphones
ipad sound only through headphones
ipad sound only works with headphones
ipad thinks headphones are in
ipad volume says headphones
iphone sound only works with headphones
iphone volume only works with headphones
sound on ipad only works with headphones
