Screen Rotation Question
This is a discussion on Screen Rotation Question within the iPad Help forums, part of the Apple iPad Discussions category; I was using my iPad and something strange happened. All of a sudden the screen rotation stopped working. And to answer the obvious question...yes, the ...
Results 1 to 5 of 5
    44436
    5 times
    Chicago
    336
    Question Screen Rotation Question
    I was using my iPad and something strange happened. All of a sudden the screen rotation stopped working. And to answer the obvious question...yes, the screen rotation function was enabled.
    I turned off the machine and turned it back on and now everything works fine. Has anyone else experienced this? What's causing it? And what can be done to correct it if it happens again? Thanks.
    20755
    7 times
    Nov 2010
    Michigan
    436
    I haven't had that happen. I have found that certain apps don't "rotate", that's just how they are. If it was with all of your stuff, then it may have been a "glitch". And turning the iPad off, frequently resolves many "glitches" as you found out. Hope this does't turn into a permanent problem for you. Good luck.
    49638
    Milwaukee, WI
    I had a similar problem, but they eventually diagnosed my accelerometer to be defective. Hopefully not the same problem..
    20755
    7 times
    Nov 2010
    Michigan
    436
    Could they fix it, or did you have to replace your iPad?
    49091
    62
    Screen rotation locked on me about a week ago....once and only time....just restarted ipad and thought nothing more of it
  1. Screen rotation issue
    By flexguy in forum iPad Help
    Last Post: 04-15-2011, 07:37 AM
  2. Replies: 7
    Last Post: 02-12-2011, 10:18 PM
  3. Who wants their screen rotation button back?
    By newfmp3 in forum iPad OS
    Last Post: 01-29-2011, 02:04 PM
  4. Screen rotation gone after firmware update??
    By ken2step in forum iPad Help
    Last Post: 12-24-2010, 04:23 PM
  5. Replies: 16
    Last Post: 12-20-2010, 06:16 PM
ipad 2 unable to rotate
ipad rotation not working
ipad rotation stopped working
ipad screen stopped rotating
ipad stopped rotating
ipad unable to rotate
ipad unable to rotate screen
ipad2 stopped rotating
my ipad stopped rotating
unable to rotate ipad 2
why did my ipad stop rotating
why does my ipad stop rotating
Tags for this Thread
