Top iPad 2 problems
This is a discussion on Top iPad 2 problems within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I'm planning to buy and iPad2 and i was just searching for any problem before ordering and here are some problems i found: " ...
Results 1 to 10 of 12
    49532
    Unhappy Top iPad 2 problems
    Hi,
    "Backlight bleeding", "Yellowing on screen", "Dead pixels" and "Wi-Fi issues".
    Anyone knows that Apple has fixed these problems recently?
    Thanks in advance
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    You could be unlucky as with any such high volume product you could get something from a faulty batch however, the good news is that Apple will replace any faulty iPad with a brand spanking new one so IMHO go ahead and buy one and start enjoying this great product and you can get all the help that you'll ever need right here.
    38516
    18 times
    Seattle
    555
    Keep in mind that some of these reports are being blown way out of proportion. For some people to even see a hint of light bleed they were loading a pure black image, cranking the brightness all the way up and going into a room with no windows and closing the door so it was pitch dark. Honestly that is just not real world use. Now some people did have real issues and it was simply a matter of going in and exchanging it. Don't worry about it, go get one and enjoy it, it's a great device
    iPad Ninja
    5787
    22 times
    Jun 2010
    2,282
    Another one here who says go for it.
    Just enjoy it for what it does and leave outdated pc expectations behind.
    It will change the way you use computers for the better.
    49532
    Exclamation
    Thank you all,
    But i have to mention that I'm going to ask one of friends to bring one iPad from Australia and i have no access to any Apple store in my location. So I'm wondering if there is any of mentioned problems with it and I can't exchange it! Anyway, how common is this problem in iPads? 1 of 10? 1 of 100?
    Thanks again
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Quote Originally Posted by hosseinyounesi
    Thank you all,
    Thanks again
    Two things....
    1) can your friend check it out before he brings it to you......
    2) as was mentioned in another thread earlier, the warranty applies even if you have no apple store in your part of the world, so in the unlikely event that you do have a problem I am certain that it can be resolved, might not be as pain free as if you lived next door to an Apple store but where there is a will, there is a way.
    iPad Guru
    30446
    12 times
    3,196
    No one knows what the failure rate is, but realistically none of the above mentioned flaws affect your normal day-to-day iPad usage.
    And just to be safe, you could ask your friend to have the iPad setup at the Apple Store, that way he or she can check that it is not a DoD unit and if there should be any obvious flaws, exchange it right away,
    49532
    @Gabriel1:
    1- yes but which of the 4 issues mentioned in the first post can be recognized by an amateur? and how?
    2- how a dead pixel problem can be solved with to no access to a apple store? Is that a physical problem or a software one?
    @DontUnderstandMyIpad:
    what do you mean by "DoD unit" and " any obvious flaws"?
    iPad Guru
    30446
    12 times
    3,196
    @Gabriel1:
    Well, three of the issues you were referring to (Screen bleeding, yellow tint and dead pixels), can be easily checked by turning the device on. Just let the Apple Store setup the iPad. Screen bleeding is light shining through the screen, i.e. there are bright spots, usually at the sides of the screen. Yellow tint is fairly obvious, everything looks more yellowish and dead pixels mean that some of the pixels don't work, which again can be easily checked by turning the iPad on.
    I would argue that if your friend cannot recognize any screen issues, then there is little to worry about.
    Regarding Wifi issues, that seems to be software related and should be fixed by iOS 4.3.2 and if it is not, then you would have to wait for another update. But the main thing to note is, that it is mostly a software issue, which can be fixed anywhere and not a hardware issue.
    Regarding your last question, I spelt it wrong, it was meant to say DOA (Dead on Arrival). Again just try the iPad once, just turn it on and see, if the screen works. By obvious flaws did I mean anything that springs into ones eye when using the device. There are always issues to be found with any item, if one is picky enough.
    Bottom-line is, if the iPad works at the AppleStore and there are no obvious flaws, (see how 3 out of 4 issues where display issues, so they are easy to spot), then there is little to worry about. Of course there is always a chance of having something break later on, but by simply trying the iPad once before leaving the country can you expect to have a working iPad.
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    @Gabriel1:
    Hmm, if someone can't see any obvious flaws then IMHO, there really aren't any, amateur or not. A dead pixel would be hardware but there is still post and couriers........there are no insurmountable problems unless you want there to be!
    I think that you are starting to make this a bigger problem than it really is, the majority of iPads are perfect. If you really want one, buy one, if there is a problem you have a warranty but If you are really that worried maybe you should treat yourself to something else?
  1. iPad 2 gps problems:(
    By jrp95 in forum iPad 2 Forum
    Last Post: 09-21-2011, 03:12 PM
  2. Problems with ipad 2?
    By RJ551 in forum iPad 2 Forum
    Last Post: 04-25-2011, 07:35 PM
  3. Problems with ipad 2?
    By RJ551 in forum New Member Introductions - Site Assistance
    Last Post: 04-22-2011, 10:36 AM
  4. problems with ipad 2
    By Fifi1992 in forum iPad 2 Forum
    Last Post: 03-12-2011, 11:48 PM
  5. Problems with New Ipad
    By Al Rogers in forum iPad Help
    Last Post: 07-14-2010, 06:33 PM
common faults with ipad 2
common ipad 2 defects
common ipad 2 problems
common issues with ipad 2
common problems with ipad 2
ipad 2 common faults
ipad 2 common problems
most common problems with ipad 2
Tags for this Thread
