Results 1 to 2 of 2
    31849
    Feb 2011
    14
    RGB to TV help please
    Today i went out and bought a Wireless Keyboard and a mouse. I am hooking up my Macbook 13.3 to my tv with the apple connector and the RGB cable. However the screen seems to be to large for my tv. Everything on the desktop looks normal but when I open firefox or any other application it is HUGE. I went into my tv settings and put it all the settings and nothing looks good. Is there a setting on the mac i should switch? Thanks for your help!!!!
    37823
    538 times
    Cranbrook, Kent, UK
    15,671
    Quote Originally Posted by Mck22
    I don't think that your MacBook can be the cause of this, I used to have my mac hooked up to the TV, had to have a play with some third party screen res programmes to get it to look right but whatever you set the screen res to that's it, it shouldn't change randomly through programmes so maybe when a new window opens your tv is detecting a change in screen size and auto changing to fit.
    You pay be better trying a specific mac forum.
    One last thing, I always used an hdmi cable to connect, the rgb cable could be the cause of your problem, not because it is faulty but just because of the way your tv handles the incoming information.
connect ipad to tv rgb
connect macbook to tv rgb
hooking my macbook pro to rgb
how do i hook up my macbook to my tv with rgb cable
how to connect mac to tv rgb
ipad to rgb cable
mac to tv with rgb
macbook to rgb cable
rgb mac to tv
rgb mac to tv setup
rgb tv macbook
use rbg cable to connect ipad to tv
