Syncing iPad Help
This is a discussion on Syncing iPad Help within the iPad Help forums, part of the Apple iPad Discussions category; I've had my iPad since January and at the time had a different computer. Since then a friend gave me a newer computer and hadn't ...
Results 1 to 7 of 7
    49057
    9
    I've had my iPad since January and at the time had a different computer. Since then a friend gave me a newer computer and hadn't synced my iPad with the new computer since I got it. Well the other day I went to sync it and because it was the first time syncing it with the 'new' computer, it asked me to install something so my pc can see the iPad and I accidentally said no forgetting I was supposed to say yes. Now I can't sync the iPad. When I go connect the ipad to the pc, I get a weird connected sound but nothing happens & then when I disconnect it, I get the usual disconnect sound when you disconnect something that's usb. My itunes doesn't even see the ipad when I connect it. Is there any way I could fix it without having to reinstall windows? I've tried uninstalling itunes & reinstalling it with the newest update but that didn't help.
    579 times
    Dayton, WA
    13,187
    I don't know enough about how Windows and iTunes work together to help, but if no more knowledgeable person wanders by soon, don't forget you can call Apple's Tech Support.
    iPad Guru
    30446
    11 times
    3,197
    You are most likely using XP and prevented the installation of the iPad USB device driver.
    The best place to look for instructions to install them again is Apple. Take a look at point 3:
    http://support.apple.com/kb/ts1538
    579 times
    Dayton, WA
    13,187
    Speaking of the .. uhm, nice person.
    iPad Addict
    15631
    2 times
    Sep 2010
    Sydney
    1,078
    Quote Originally Posted by ksaikin
    Which version of Windows are you on? I had a similar issue with my iTunes on Win7, where iTunes would not recognize the iPad when plugged in. However, Win7 would recognize the iPad and offer its own popup window (when it sees a new external device plugged in). After I told the popup box to 'do nothing' and clicked it away, I could unplug and reconnect my iPad (iTunes still open) and then iTunes finally picked it up.
    32GB WiFi
    49057
    9
    I am running XP and when I went into the My Programs Property manager & device manager, I did NOT see the Apple ipad usb device driver in the list of usb device drivers. I can't call Apple Care as I can't afford the care plan right now. The only other thing I can/have to do is go to the apple store or just deal with not being able to sync the ipad if I can't install the drivers. Is there anywhere I can download the apple ipad usb device driver?
    49057
    9
    thank you all...got it working!
  1. ipad syncing
    By bskinner in forum iPad General Discussions
    Last Post: 05-01-2011, 03:11 PM
  2. Syncing iPad without syncing music
    By Mike_73 in forum iPad Help
    Last Post: 01-10-2011, 03:49 AM
  3. Need help with ipad syncing
    By pakogah in forum iPad Help
    Last Post: 09-17-2010, 08:26 PM
  4. IPad and SQL syncing
    By Billydon in forum iPad Apps
    Last Post: 09-11-2010, 07:00 PM
  5. Syncing Ipad!
    Last Post: 09-05-2010, 07:39 PM
i connect i ipad to pc but nothing happen
i plug my ipad into my computer and nothing happens
i've connected my new ipad to my mac laptop and nothing is synching
if i plug my ipad into computer and nothing happens what is wrong
my ipad sync but nothing happen to my ipad
plug ipad into computer and nothing happens
what do i do when i connect my ipad to my pc but nothing happens
what should happen when i plug in my ipad
what will happen if i plug my ipad into a different computer
when i attach my ipad to my computer nothing happens
when i connect my ipad nothing happens
when i plug my ipad into my computer nothing happens
