Earphone Jack Problem
This is a discussion on Earphone Jack Problem within the iPad Help forums, part of the Apple iPad Discussions category; I'm not getting any sound through my earphones when I plug them in. I promise I've pushed hard enough, the music or video is playing, ...
Results 1 to 10 of 11
    48518
    Indiana
    I'm not getting any sound through my earphones when I plug them in. I promise I've pushed hard enough, the music or video is playing, and I tried three different sets (one brand new). Still, nothing comes out, just a little bit of static when I turn it all the way up. I've had my Ipad for three months now, and this has never happened. I would really love it if someone could solve this problem for me. Thanks.
    9323
    Jul 2010
    Southeast Wisconsin
    672
    Did you by chance change the rocker switch on the side to mute? Check in your Settings app under the "General" tab.
    Sent from my IPad
    1524 times
    Walla Walla, WA
    15,435
    That the mute switch should not affect music playback, at least for Apple apps. It is hit or miss with other apps, depending on how the developer coded them.
    Ideally the mute switch is only supposed to turn off alerts and system sounds.
    This is a long shot too, but check Settings >> iPod >> Volume Limit. This will create an upper volume limit for your music (for the iPod app at least). If it was set to nothing it might cause this.
    But you should also try another pair of headsets. In my experience a slight difference in the length of the headphone jack has cause seating problems. Many cheaper headphone jacks lack precision in the length measurements. This can be vital because Apple uses a four conductor jack (for the microphone) instead of the standard three used by most headsets, and if they don't seat just right they may not work.
    48518
    Indiana
    I've switched the mute button on and off a few times and it doesn't make a difference. And like I said, I tried three different sets of headphones, all different brands, one of which I've used on it since I first got my Ipad. But thank you for both of your siggestions.
    1524 times
    Walla Walla, WA
    15,435
    Sorry, I missed that. Reading too fast.
    No idea. I guess it could have gone bad. Happens. You may have to talk to Apple.
    88850
    Aug 2011
    Quote Originally Posted by ParadiseLane View Post
    same thing happened to me and my ipad is already 9 months old. i was already thinking of bringing it to an apple store when suddenly, after a week and a half after the problem occurred, the earphone jack suddenly worked. whew! maybe something just got loose inside.
    1524 times
    Walla Walla, WA
    15,435
    Quote Originally Posted by huff
    Mine did this recently (since my last post in this thread), and cured itself over night. I did some reading, the gist of whish is that it is usually caused by dust in the jack. It blocks the sensor (optical?) so that the iPad (iPhone in my case) thinks the headphones are plugged in. That makes sense to me. I'd just finnished some weed whacking, and the phone did get dusty.
    88850
    Aug 2011
    i knew it was too good to be true. my problem with the jack came back. thanks twerppoet, will try to clean it up.
    1524 times
    Walla Walla, WA
    15,435
    Just be careful. You don't want to damage the jack by jamming things into it.
    62766
    2 times
    Jun 2011
    Washington state
    79
    You remember that the headphone jack and the iPad speaker have separate volume controls, right?
    Beyond here, there be dragons.
  1. Earphone jack
    By Esskay in forum iPad Help
    Last Post: 06-30-2011, 12:33 PM
  2. Folio with earphone storage ipad2
    By Jer99 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 04-14-2011, 07:58 PM
  3. earphone jack..... loose?????
    By SheerLuckHolmes in forum iPad General Discussions
    Last Post: 04-12-2011, 09:39 PM
  4. Earphone imbalance
    By Justinfromwork in forum iPad Help
    Last Post: 01-16-2011, 05:12 AM
  5. HEADPHONE JACK IN IPAD MAY ACCEPT HEADSET? This headset must has only one jack?
    By lse123 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-23-2010, 06:13 AM
ipad 2 headphone jack not working
ipad 2 headphone jack problem
ipad air headphone jack problem
ipad earphone jack problems
ipad earphone problem
ipad headphone jack not working
ipad headphone jack problems
ipad problems with earphone connector
Tags for this Thread
