Using simcard overseas
This is a discussion on Using simcard overseas within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I'm going to Turkey for a few weeks and was told that I can get a simcard over there for my iPad -- much ...
Results 1 to 3 of 3
    47626
    Massachusetts
    Hi,
    I'm going to Turkey for a few weeks and was told that I can get a simcard over there for my iPad -- much less expensive than AT&T 3G with better coverage.
    Is the simcard for the iPad just an ordinary cellphone simcard that I'll be able to buy at a Post Office in Turkey? Or is it a special rare variety that might be impossible to find. Would it be safer to buy the AT&T International service as a back-up?
    Thanks to anyone who can shed light on this.
    Jane O
    116 times
    15,249
    As you probably know, the iPad uses a newer type of SIM card called the microSIM, which is used by the iPhone4 and the iPad. These are significantly less common than the regular SIM. As a result, if you're planning to get a SIM when you get to Turkey, you might want to invest a few dollars in a SIM-cutter. This will cut a regular SIM down to microSIM size. It sounds a bizarre procedure until you realise that the 'excess' being cut off the regular SIM to bring it down to microSIM is simply plastic. You can get these cutters easily in the US from retailers such as Amazon.
    Details of the GSM operators in Turkey can be found here
    Using Mobile Phones in Turkey | I was in Turkey
    I hope you enjoy your trip.
    47626
    Massachusetts
    simcard overseas
    Tim -- thanks a million. This is exactly what I needed to know. The article is loaded with useful information, also.
    I appreciate your responding so quickly.
    Jane
  1. Ipad crashes when using SIMcard
    By ronaren in forum iPad Help
    Last Post: 03-19-2011, 10:00 PM
  2. Use your iphone simcard and get free 3g data on ipad 3g.
    By MikesTooLz in forum iPad Carriers
    Last Post: 02-08-2011, 01:19 AM
  3. NETFLIX Overseas
    By Mickeybros in forum iPad FAQ
    Last Post: 01-26-2011, 03:04 AM
  4. Urgent! Going overseas tmr
    By adellewee in forum iPad Help
    Last Post: 12-15-2010, 07:03 AM
  5. AT&T 3G network overseas
    By michaelruggeri in forum iPad Carriers
    Last Post: 04-20-2010, 02:54 PM
can a turkish sim card be used in at&t iphone
internet access overseas ipad sim cards
ipad sim card in turkey
ipad sim card turkey
ipad sim turkey
iphone sim card turkey
overseas sim card for ipad
sim card for ipad overseas
turkey sim card iphone
using an iphone in turkey
using ipad overseas
using iphone in turkey
