Problem with software update
This is a discussion on Problem with software update within the iPad Help forums, part of the Apple iPad Discussions category; I have been waiting for 3 hours. The picture of the usb cable to iTunes is on my ipad screen. iTunes site says my ipad2 ...
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By MacClanIII
Thread: Problem with software update
    17092
    Oct 2010
    upstate ny
    16
    I have been waiting for 3 hours. The picture of the usb cable to iTunes is on my ipad screen. iTunes site says my ipad2 is updating. I haven't unplugged anything...why is it showing the usb plug to itunes picture?
    dylsmom1 likes this.
    116 times
    15,249
    Quote Originally Posted by MacClanIII View Post
    Is this a brand new iPad that you're plugging into your PC for the first time - i.e. the first time initialisation - or are you trying to perform a sync operation?
    What version of iTunes do you have? It needs to be at least 10.1 - earlier versions will not work correctly.
    17092
    Oct 2010
    upstate ny
    16
    Thanks Tim
    Hey thanks for the quick help response...I have had it for a week. I did set it up already...have been using a lot. I have been having problems with the syncing...sometimes it recognizes the ipad sometimes it doesn't. if I unplug the usb cable and plug it into a different pc port...it then works. The iTunes version is 10.2.1.1 I get an error message that says the ipad can not be synced. An error occurred while writing to this device. Another error message said cannot find the drive. I called Apple and they said they would replace it. It will take two weeks.
    17092
    Oct 2010
    upstate ny
    16
    more info
    I just tried to plug it into my pc again and now it doesn't recognize the ipad2...iTunes shows no device. Are the ipad2's having issues or is it just the one I received. I am using the main usb on the back of my pc. I have a new alienware aurora...maxed out.
    iPad Junkie!
    37021
    223
    Well, that's a bummer. iTunes was updated yesterday; one of the fixes supposedly deals with sync problems. Maybe if you try installing the latest version, it will solve your problem. At least, I hope so.
    17092
    Oct 2010
    upstate ny
    16
    Unhappy update on my sync problems
    Well I reset my ipad2 back to factory level...I unautherized my itunes and then rauthorized it. I uninstalled itunes and then reinstalled it making sure i had latest version. I kept my fingers crossed and tried to sync my ipad to the computer and itunes. It worked at first...I tried installing a few free apps and some pod casts. Everything worked fine. I tried unchecking the "manually mange music" box and it asked me if I was sure. I did it anyways. I tried to sync and it worked.
    Ok so what is the problem? Well I just closed itunes and turned off the ipad2 and shut down the pc. I then restarted the pc, turned on the ipad2 and watched as the sync began between the ipad2 and my pc. The ipad can not be synced, an error occured while writing to this device. Then another eror: "itunes cannot find the ipad2 disk. I called apple and they said return it by taking it to the ups store, give them the provided repair id and they will ship it to apple repair. They said I will be shipped a new ipad2. I had engraving on my original but decided not to get this replaced on the second one because of shipping time. I will tell you how I make out. I waited 5 weeks for an ipad2 and now after a week I have to send it back. Hope the next one isn't a lemon.
    iPad Guru
    30446
    11 times
    3,197
    Just out of curiosity, which operating system are you using?
    It doesn't happen to be XP x64?
    17092
    Oct 2010
    upstate ny
    16
    I also checked to see if i had the latest version of ipad2 sotware and I do. Is this a common ipad2 problem? Is my ipad2 like others the way it syncs on an inconsistent schedule? I am sending it back anyways...and hope that the replacement works everytime when I sync it. I had an itunes account a year ago for my ipod but stopped using it for a while. I bought a new pc and had maxed out the 5 authorizations. I called apple and they extended my number of authorizations by 5. Could this be where my problem lies? Is the ipad2 effected by my itunes history?
    17092
    Oct 2010
    upstate ny
    16
    sync problem
    Hi,
    I have an alienware aurora that is a few months old. It is maxed out. Windows 7... 64 bit...and all that other good stuff that you see techies bragging about...and now I finally can say that.
    iPad Guru
    30446
    11 times
    3,197
    Hi,
    In that case, should it work.
    It was just an idea, as XP x64 causes problems, but any other OS works fine. Your setup should definitely handle an iPad 2.
  1. How Do I Update my iPad's Software?
    By pdmike in forum iPad General Discussions
    Last Post: 12-31-2010, 10:24 PM
  2. problems after iPad software update
    By pamk-ipad in forum iPad General Discussions
    Last Post: 11-28-2010, 07:44 PM
  3. Replies: 2
    Last Post: 07-30-2010, 10:10 AM
  4. iPad Gets iOS 3.2.1 Software Update
    By Maura in forum Apple iPad News
    Last Post: 07-23-2010, 05:04 PM
  5. IPad software update for wireless?
    By pallentx in forum User News Submissions
    Last Post: 07-15-2010, 05:32 PM
ipad an error occurred while checking for a software update
ipad software update 3 hours
ipad software update 3 hours remaining
ipad software update 4 hours remaining
ipad software update error
ipad software update takes 3 hours
ipad unplugged during update
ipad2 missing software update
ipod software update waiting
software update on ipad2 missing
software updates not in settings on ipad2
why is software update not an option on my ipad2
