Rotation Lock Stuck
This is a discussion on Rotation Lock Stuck within the iPad Help forums, part of the Apple iPad Discussions category; Originally Posted by Tom.Stevenson
I agree with you that users of any item should learn how it works, but although I found my screen orintation ...
Tom.Stevenson
I agree with you that users of any item should learn how it works, but although I found my screen orintation icon in locked mode, and it was simple enough to unlock it, my screen rotation remains locked.
So how do you have the side switch set in settings? To what value? And did you change the setting after you set rotation lock?
If so, set the SWITCH back to "rotation lock" UNLOCK the screen using the switch, and then set the switch to whatever value you want it to be. I'm assuming MUTE. That should get you out of the mess...
07-19-2011 08:47 AM
You wrote "So how do you have the side switch set in settings? To what value? And did you change the setting after you set rotation lock?
If so, set the SWITCH back to "rotation lock" UNLOCK the screen using the switch, and then set the switch to whatever value you want it to be. I'm assuming MUTE. That should get you out of the mess..."
Well there's one that is not in the manual. How are users supposed to learn that? The SWITCH was set to MUTE, which is as it should be, if you don't want to lock the rotation, but seconds after posting my reply I received a new OS version 4.3.4 (mine was 4.3.3) and installing that unlocked the rotation.
Whether the bug has been fixed or it was simply the rebooting effect of an updated OS remains to be seen.
However, I hope that it is a bug that has now been fixed because if it is simply a matter of accidentally changing the settings, then whatever you or anyone else says about learning how iPad2 works, the sheer number of people who have experienced this problem illustrates that it is not as intuitive as it should be.
Rotation Lock Stuck!
Hey just want to say thanks to whomever wrote to restore IPAD2 to get it unstuck from Landscape mode. While I'm aware all technology has their glitches, I am just so thankful there are people who take the time to offer true Simple help , to others like me. You make it enjoyable to troubleshoot ! And.... As long as something works I'm happy so thanks.
I currently have this problem. I was using it in a meeting earlier in landscape. Came home, opened it up and it came on in portrait (it was flat when started up). I then rotated it and nothing happened.
Really confused and at a loss as I have:
- Turned off all apps
- Checked all settings as mentioned already
- Power down
- Reset (holding down home and power buttons until the apple logo appears)
Nothing is working. It's only 2 weeks old so not too happy that this has happened, especially as apart from this it has been brilliant.
Any ideas?
pmt008
- Power down
Any ideas?
Slide the switch on the side of the iPad and see if that fixes it.
Also, what do you have the side switch set to do in the settings app?
As I said, I did all the settings stuff previously mentioned in this thread. The switch is set to volume. The double click of the home button menu setting for rotation is unlocked. I have set it to be on, turned it off and then turned it back on and unlocked it and it's not worked. I have even tried the tapping method, but still no joy.
f4780y
There are 2 ways you can lock the rotation. Do you have the switch on the side set to rotation lock or mute? You can check this in Settings > General. If set to rotation did you accidentally hit the switch?
Next if you bring up the task switcher and slide it to the right, you may have the rotation lock control on the left hand side (if the switch is set to mute). Did you accidently hit that?
Those are the 2 things to check if it happens again...
Hope that helped.
The second solution fixed this issue for me. Thanks for contributing to others! 😊
codie261
The second solution fixed this issue for me. Thanks for contributing to others! dde0a
You are very welcome. Glad you got your problem solved!
- You may not post replies
- You may not edit your posts
Forum Rules
By GailLA in forum Apple iPad Polls
Last Post: 06-27-2011, 08:37 AM
By luigifonti in forum iPad Help
Last Post: 04-14-2011, 10:48 AM
By Stephen19 in forum iPad Help
Last Post: 03-31-2011, 04:08 AM
By Maura in forum Apple iPad News
Last Post: 01-13-2011, 04:47 PM
Last Post: 12-20-2010, 06:16 PM
after i reset ipad 2 stuck in circle rotation
how to remove lock rotation ipad
how to unlock rotation on ipad 2
how to unlock the rotation on my iphone5
ipad 2 rotation lock stuck
ipad 2 rotation stuck
ipad lock rotation stuck
ipad rotation lock stuck
ipad rotation stuck
ipad stuck in landscape
lock rotation ipad 2 stuck
my ipad is stuck on lock rotation
