disappearance of the symbol of wifi signal
This is a discussion on disappearance of the symbol of wifi signal within the iPad Help forums, part of the Apple iPad Discussions category; Hi guys.. I just wonder you have the same problem of ipad2 wifi signal symbol I just can not find the symbol of wifi which ...
Results 1 to 6 of 6
    46446
    garyk630@gmail.com
    Hi guys..
    I just can not find the symbol of wifi which is supposed to be the top-left in the screen of ipad2, even though I can access the internet.
    what's wrong with my new ipad2???????
    116 times
    15,249
    Quote Originally Posted by garykao View Post
    Hi guys..
    Do you have a 3G iPad? If so, and WiFi is not available, it will connect to the Internet using 3G and no WiFi symbol will be displayed.
    46446
    garyk630@gmail.com
    No 3G
    Hi guys..
    . I only have wifi ..... What should i do to fix this problem?? Update new version of iPad??
    116 times
    15,249
    iPad Ninja
    3495
    27 times
    May 2010
    Switzerland
    2,017
    I had the same problem. I troubleshot it down to a Wifi repeater. The iPad works still, but Apple should look into it.
    46446
    garyk630@gmail.com
    thanks a lot
    I just tried to restart my ipad...
    My symbol of wifi just surprisingly appear
    thanks for your solution ^^
    garykao
  1. Wifi signal booster help
    By Woodwitch in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 12-15-2011, 10:43 PM
  2. Wifi signal strength
    By jwdave in forum iPad General Discussions
    Last Post: 08-20-2010, 11:59 PM
  3. Wifi Symbol Disappeared after jailbreak
    By spiderguy84 in forum iPad Hacking
    Last Post: 08-08-2010, 04:09 PM
  4. WiFi Signal Strength Terrible
    By MrLee in forum iPad Help
    Last Post: 08-07-2010, 04:56 AM
  5. Weak signal with Cisco M10 WiFi Router
    By jfdonohoe in forum iPad Help
    Last Post: 07-08-2010, 08:28 PM
ipad no wifi icon
ipad no wifi signal
ipad wifi icon disappeared
ipad wifi icon missing
ipad wifi symbol missing
iphone no wifi icon
iphone wifi icon missing
no wifi icon on ipad
no wifi signal on ipad
no wifi signal on ipad 2
no wifi symbol on ipad
wifi icon on ipad is gone
