Itunes Sync Issues
This is a discussion on Itunes Sync Issues within the iPad Help forums, part of the Apple iPad Discussions category; Syncing 3G iPad and I keep getting the following error...iPad cannot be synced, you do not have the privileges to make the changes. Any idea ...
Results 1 to 2 of 2
    3436
    May 2010
    5
    Itunes Sync Issues
    Syncing 3G iPad and I keep getting the following error...iPad cannot be synced, you do not have the privileges to make the changes. Any idea what is wrong?
    Update...I think I figured it out. I reset all sync options back to default and changed them one at a time and sync'd. It appears to be the photos I was trying to sync.
  2. #2
    14674
    Sep 2010
    New York
    Ipad error 39
    I got lot of very annoying error 39 messages. I am surprised this problem has still not been corrected with an update.
    Anyway, it had to do with Ipad photos. Here's the solution; Deselect (remove the check marks) from all the photos folders you you have presently selected in "photos". Synch the ipad and it will remove all the photos from the ipad. So you start clean. Now go back and put check marks on all the phot albums you want to synch and it corrects the problem. Good luck
Sponsors
  1. Hotmail issues
    By Marla in forum iPad Help
    Last Post: 02-23-2011, 03:19 PM
  2. How to Fix the iPad's Wi-Fi Issues
    By cimousa in forum iPad Help
    Last Post: 04-28-2010, 01:09 PM
  3. Wil 3G iPads have WiFi issues?
    Last Post: 04-25-2010, 12:27 AM
  4. Replies: 6
    Last Post: 04-22-2010, 01:01 PM
  5. Audio Out issues while iPad is docked
    By 4phun in forum iPad Help
    Last Post: 04-18-2010, 10:25 PM
error message when syncing ipad
error syncing ipad
ipad cannot be synced unknown error 39
ipad cannot be synced unknown error 50
ipad cannot be synced you do not have the privilege to make changes
ipad error 50 sync
ipad photo sync error
ipad privileges
ipad sync error
ipad sync error 39
ipad sync error 50
ipad sync error message
ipad sync errors
ipad sync issues
ipad sync problems
ipad sync unknown error 50
ipad syncing error
the ipad cannot be synced you do not have the privilege to make changes
the ipad cannot be synced. you do not have the privilege to make changes
