Hi, was just upgraded to 3.5, and now the darn thing just sits there. I see on the App store that others are having the same problem. Any ideas? It was a great app.
Thanks!
This is a discussion on Frendly for Facebook won't load within the iPad Help forums, part of the Apple iPad Discussions category; Hi, was just upgraded to 3.5, and now the darn thing just sits there. I see on the App store that others are having the ...
Thanks!
Have you restarted the iPad? That should help.
Reboot you'll be fine. Same thing happened here.
Btw, I usually do know how to spell...Friendly. How does one edit a post?
You guys are great! And fast! I had done a restart and nada, synced to ITunes, nada, hard reboot and it worked! Thanks!
