Results 1 to 5 of 5
    45783
    USA
    Email will not send
    I have recently started having a problem with sending email from my iPad. Sometimes after hitting send it appears to be sending but does not end up in my sent box and is not received by the recipient. There is no error message and I wouldn't even know it wasn't sent if I didn't check the sent box. Please help, this is very frustrating.
    116 times
    15,249
    I've had this problem too!
    45783
    USA
    Neither of those worked. Anyone else?
    iPad Guru
    30446
    11 times
    3,197
    The email most likely got stuck in the Outbox. The bottom left corner, where is usually says Checking Mail, should now be a message saying '1 unsent message'.
    Anyway, where you able to send emails with the same account before? Is it an email account from Work/Uni? Sometimes you have to be on the premises to be able to send emails, though receiving mails still works.
    45783
    USA
    This is Yahoo mail and I don't see an outbox or a message that says "unsent". This is very frustrating.
  1. Cannot send from godaddy email accounts
    By ByHisStripes in forum iPad General Discussions
    Last Post: 03-14-2012, 01:30 PM
  2. Send email attachment/photos
    By Vanphen wagner in forum iPad Help
    Last Post: 11-24-2011, 02:56 PM
  3. How To Send PDF Attachments in Email?
    By DUTCH VanAtlanta in forum iPad General Discussions
    Last Post: 04-09-2011, 09:13 PM
  4. Email won't send
    By Dancemom in forum iPad Help
    Last Post: 02-03-2011, 02:40 PM
  5. Help - the email send does not work
    By arnielh in forum iPad Help
    Last Post: 07-28-2010, 03:51 PM
how to delete unsent yahoo mail in outbox on ipad2
how to send unsent messages on ipad
ipad won't send our unsent messages
ipad yahoo mail stuck in outbox
yahoo email stuck in outbox ipad
yahoo mail ipad stuck in outbox
yahoo mail not sending emails ipad
yahoo mail outbox ipad
yahoo mail safari ipad stuck outbox
yahoo mail stuck in outbox ipad
yahoo mail stuck outbox ipad
yahoo outbox won't send
