i-pad won't turn on
This is a discussion on i-pad won't turn on within the iPad Help forums, part of the Apple iPad Discussions category; I've tried searching the threads and can't seem to find an answer. Anyone out there help? For reasons best known to itself my i-pad will ...
Results 1 to 10 of 12
    45776
    jeddah
    i-pad won't turn on
    Anyone out there help? For reasons best known to itself my i-pad will not now turn on, I've tried charging, it does not even recognise that it's being charged. I've tried to reconnect to my laptop, computer doesn't recognise anything is plugged in.
    I'm in Saudi Arabia and would prefer to find some sort of intelligent answer before visiting the apple shop (if you lived here you'd know why!)
    Thanks in advance.
    116 times
    15,249
    Don't worry - there's a simple fix.
    Press and hold down the Power and Home buttons for about 60 seconds - yes, you read that right - sixty - until the white Apple logo appears. The iPad will reboot - it takes a while, so you need patience. No files or apps will disappear - it's nothing more than a reboot. We all have to do it now and again
    Good Luck and let us know how you get on.
    45776
    jeddah
    Thanks Tim
    GF says the apple logo came up at around the 5sec mark, kept holding for the advised 60 secs, nowt seems to be happening now, have I done something wrong?
    Cheers.
    45776
    jeddah
    Fixed and now charging, thank you sooooooo much!
    116 times
    15,249
    Quote Originally Posted by camdxr View Post
    No problem...it's a heart stopping experience!
    Have fun and enjoy Saudi!
    46735
    I have the same problem as camdxr. I've tried holding the power and home buttons down but it's not doing anything.
    116 times
    15,249
    Quote Originally Posted by neale75 View Post
    OK - let's back up a little bit.
    Is this a new iPad that you've never used before, or have you been using it and it's now stopped working? Is it an iPad1 or iPad2?
    I'm assuming that, if it's just stopped working, the screen is blank and pressing the Power button by itself has no effect?
    Is your iPad fully charged? We've had several people who have had problems with their iPad because they accidentally left it on and the battery went flat and then it wouldn't restart but it was really a flat battery problem.
    Tell us a little more...and we'll be sure to do whatever we can.
    46735
    Ipad 2. I'd had it 3 days, and it had been working fine. I charged it up, used it for a bit, switched it off then went to bed. Yesterday when I went to use it again nothing happens. I've tried the reboot and that didn't work. I even plugged it in just incase I'd left it switched on and the battery had died but that didn't wortk either. I think I'll take it to the Apple Store today.
    116 times
    15,249
    OK - it could, of course, be a faulty iPad but that's unusual - particularly if it's been working properly before. How long did you leave it on to charge? If the battery is completely flat it will need a couple of hours before there's enough charge to successfully reboot, so you might want to leave it plugged in and always make sure you're using the iPad charger and not a USB port or an iPod charger as they supply significantly less current and will therefore take correspondingly longer to charge.
    When you try the reboot - how long did you try holding down the Power and Home buttons for (at the same time). It can take a while - I've had members report having to wait 60 seconds though, when I've had to do it (once only) on my iPad it was significantly less than this.
    49136
    Florida
    I apologize for jumping in on this thread--I just logged into this site because I'm having the same problem.
    I've had my iPad since Christmas. Used it regularly there for a while. Left it at my family's home and I wasn't able to have it. I'm assuming my battery completely died, like you're explaining here, Tim. I finally got my iPad back--went out and bought a new charger, though, as no one seems to know where the charger that came with the iPad has disappeared to (including the wall-adapter). I've got it plugged into my Mac now but nothing's happening. I've tried the reboot--and there's nothing.
    I guess my question is--will a regular charger do the trick, just plugged into my computer via the USB? (I fear the answer to this question is probably "no"). I'll be happy as long as my iPad isn't completely broken.
    Thanks for any help you might have!
    - Sarah
  1. Do you turn off your ipad?
    Last Post: 07-31-2011, 09:58 PM
  2. Help! My ipad won't turn on:(
    Last Post: 04-18-2011, 04:05 PM
  3. New! Cant turn on ipad????
    By kygal in forum New Member Introductions - Site Assistance
    Last Post: 01-04-2011, 01:01 PM
  4. When to Turn Off iPad
    By jossef in forum iPad General Discussions
    Last Post: 01-02-2011, 10:47 AM
  5. Replies: 7
    Last Post: 06-03-2010, 03:34 AM
i pad 3 wont turn on
i pad will not turn on
i pad won't turn on
i pad wont turn on
ipad charged but will not turn on
ipad takes a long time to turn on
ipad takes long time to turn on
ipad wont turn on even when plugged in
my i pad is charged but won't turn on
my i pad won't turn on
my i pad wont turn on
my ipad wont turn on when plugged in
