iPad 2 WiFi issues... Frustrating!!
This is a discussion on iPad 2 WiFi issues... Frustrating!! within the iPad Help forums, part of the Apple iPad Discussions category; I've found that other ipad 2 owners are experiencing the same issues as myself. I know it's not my network. My ps3, MacBook, iPhone, evo ...
Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 37
    45431
    19
    I've found that other ipad 2 owners are experiencing the same issues as myself. I know it's not my network. My ps3, MacBook, iPhone, evo 4g etc all connect perfectly. This is very annoyng!!
    Basically it drops signal frequently. Especially when resuming from sleep. Have two different routers. Sometimes it picks up both. Often times just one or the other. Even had trouble picking up a signal period. Like I said everything else works great. Freaking apple... Btw this is my second iPad 2 (first had a blown mic) and the problems are still here.
    45431
    19
    Is this apples way of getting us to purchase 3G models? Haha! I'm using 32gb wifi...
    iPad Enthusiast!
    2930
    Apr 2010
    Boise
    90
    Quote Originally Posted by iRockSteady
    Basically it drops signal frequently. Especially when resuming from sleep. Have two different routers. Sometimes it up both. Often times just one or the other. Even had trouble picking up a signal period. Like I said everything else works great. Freaking apple... Btw this is my second iPad 2 (first had a blown mic) and the problems are still here.
    Have you updated to current iOS 4.3.1? Sometimes that can resolved issues by updating the firmware. iPad 1 had some similar issues with wifi antenna back then. You want to isolate the issue first. If firmware doesn't resolved your issue, then it's definitely hardware issue.
    iPad 2 32gb Black ATT 3G
    7684
    Jun 2010
    112
    Before upgrading the OS of my original iPad I had the same type of connection issues. After upgrading to the newer OS the connection issues went away. I have never had any connection issues with my iPad 2 from the get go. Wonderful device, finds all available wifi networks within it's range and connects easily to them including my phone as a hot spot when used in that manner.
    116 times
    15,249
    Quote Originally Posted by iRockSteady View Post
    A number of members have reported similar problems. I guess you've tried the 'fix all problems' first step cure for the iPad - complete power down and then power up, which seems to cure a significant proportion of iPad 'ills'.
    If not, then one of our moderators has suggested this when members were reporting problems with WiFi after upgrading to a recent version of iOS and I wondered if it might help here.
    This has resolved many issues and worth a try.
    __________________
    Cheers
    Col
    col.bris, Brisbane Australia
    Hope this helps but, if not, please get back to us.
    iPad Enthusiast!
    39019
    Midwest
    66
    I've been fairly happy with the wifi but as far as Apple products go I only have the iPod touch to compare it with, and have 2 of those, both 4g, and they are the worst at dropping signals of any device I have ever owned.
    However if I compare the iPad to my Sony laptop, or kindle, or my phone, all those rarely drop a signal. So guess it depends on what you are used to. It works well enough for me most of the time, but not nearly as good as my other devices.
    45431
    19
    Yes I've upgraded to 4.3.1. That did nothing as far as resolving these issues. I'm going to try to do a network reset. Thanks for the help.
    iPad Enthusiast!
    2930
    Apr 2010
    Boise
    90
    Also try other wifi areas, to see if whether is your router or not.
    45431
    19
    Just did a network reset and this issue is kicking my ass. Right before the reset the wifi was working decently... At that moment. After the reset I couldn't pick up ANY signal. After allowing the searching circle to do its thing a few times, I disabled wifi then enabled it immediately and found one of what should be two available signals.
    I would bring the iPad back, but like I said this is my 2nd one, both having the exact same issue. I've gone through my network configuration numerous times and everything is how it should be. That pretty much boils it down to an iPad bug. Hope they fix it soon.
    FYI I am using a Medialink Wireless N Router broadcasting in b/g/n mode w WPA2 encryption. I've tried using just N mode, tried turning WPA2 off etc etc
    So far I haven't found a solution.
    iPad Enthusiast!
    2930
    Apr 2010
    Boise
    90
    Like I said try any coffee shop that offers free wifi. Also you said you are running 2 routers? That also can contribute to your problem. Turn one them off and just run one of them alone. They may be causing some interference.
  1. Replies: 6
    Last Post: 01-20-2012, 07:33 AM
  2. help with WIFI issues
    By addiosamigo in forum iPad Help
    Last Post: 01-05-2011, 09:46 AM
  3. Wifi issues
    By Gringop20 in forum iPad Help
    Last Post: 09-28-2010, 09:51 PM
  4. Wifi Issues Fixed?
    By candafilm in forum iPad General Discussions
    Last Post: 05-30-2010, 12:45 AM
ho w to fix ipad 2 wirelee problem
how to fix ipad 2 wifi issues
ipad 2 32gb wifi issues
ipad 2 wifi issues
ipad 2 wifi issues fix
ipad 2 wifi problem fix
ipad 2 wifi problems
ipad 2 wifi problems fix
ipad drops wifi after sleep
ipad help
ipad slow medialink router
medialink router ipad
