IPad won't start
This is a discussion on IPad won't start within the iPad Help forums, part of the Apple iPad Discussions category; I had my IPad on, then turned it off. A minute later, I went to turn it on again and it wouldn't turn on. I ...
Results 1 to 7 of 7
    34668
    Feb 2011
    Nh
    IPad won't start
    I had my IPad on, then turned it off. A minute later, I went to turn it on again and it wouldn't turn on. I plugged it in thinking it might have a low battery and it a) won't turn on even though plugged in and b) didn't make the little noise that it usually does when it is plugged in and charging. It is the original IPad and about 4 months old. Help???!!!
    44796
    3 times
    Johannesburg
    255
    Have you tried resetting by holding the down home and power button for a few seconds?
    1522 times
    Walla Walla, WA
    15,429
    Takes more than a few seconds. Hold them down until the Apple Logo appears. This usually takes about 15 - 20 seconds, though I've heard others suggest up to 60.
    34668
    Feb 2011
    Nh
    I did see that in another thread and tried it. It did work, though I'm still a bit worried about why it just kind of died in the first place. Thanks for the feedback. For my instance, it took about 15 seconds.
    119 times
    15,248
    Quote Originally Posted by Iguanaroar View Post
    Don't worry about it. It happens to all iPads occasionally and isn't an indication that there's anything seriously wrong. Only start to worry if it becomes a frequent problem.
    117868
    Oct 2011
    11
    Unhappy Help!!!!!!!!!!!!!!! Ipad problem
    um... hey guys i was wondering if there a problem fixed or an ipad wich shows the rotating loading and and apple logo over and over HELP!!! plz
    thanks for anyone who can fix the problem
    1522 times
    Walla Walla, WA
    15,429
    Have you tried a reset?
  1. iPad 2 won't start properly
    By tracey in forum iPad 2 Forum
    Last Post: 08-20-2011, 02:25 PM
  2. Used iPad 3G how do I start service
    By iDocMike in forum iPad Help
    Last Post: 03-18-2011, 07:17 PM
  3. Cannot start DocksToGo on Ipad
    By onno in forum International iPad Users
    Last Post: 02-02-2011, 02:34 PM
  4. iPad doesn't start
    By ericopf in forum iPad Help
    Last Post: 01-31-2011, 05:53 PM
  5. Just got an ipad! Need help to start up!
    By foxtrot in forum iPad Help
    Last Post: 07-20-2010, 09:22 AM
ipad 1 wont start
ipad 2 wont start
ipad low battery won't turn on
ipad won't start
ipad wont boot up
ipad wont start
ipad wont start up
original ipad wont turn on
Tags for this Thread
