when typing email address, it drops the first letter
This is a discussion on when typing email address, it drops the first letter within the iPad Help forums, part of the Apple iPad Discussions category; I start typing and as I am typing, the first letter disappears and I have to manually go in and retype it. Anyone know how ...
Results 1 to 2 of 2
    38481
    I start typing and as I am typing, the first letter disappears and I have to manually go in and retype it. Anyone know how to fix this?
    Thanks!
    Dabber
    116 times
    15,249
    OK - let's try the simple things first!!!!! Simple is good..
    If this doesn't work please get back to us and we'll move to a new solution...
  1. Defaulting email address
    By Splicer in forum iPad Help
    Last Post: 03-20-2011, 08:40 PM
  2. Problem Entering Email Address
    By DennisS in forum iPad General Discussions
    Last Post: 12-28-2010, 07:15 PM
  3. Ipad having problems with school email address?
    By Calevra in forum iPad General Discussions
    Last Post: 10-05-2010, 08:38 AM
  4. Hoe to change the reg email address.
    By roses in forum iPad Help
    Last Post: 09-03-2010, 07:29 PM
  5. Was Your Email Address Hacked?
    By CaptKirk in forum iPad General Discussions
    Last Post: 06-10-2010, 01:41 AM
address disappears when typing email
apple i pad problem typing om e-mail
begin typing and first character
e-mail reply drops letters from address
first character dropped when typing
hotmail to address appearing with first letter
ipad dabber
list email addresses when typing the first letter
next letter drops while typing email
typing email adresses
when emailing contact does not appear after typeing first letter
Tags for this Thread
