Results 1 to 10 of 16
Like Tree1Likes
Thread: Help with sound
    44769
    Winston-salem
    5
    Help with sound
    The sound on my iPad works for YouTube and the iPod but the sound no longer works for games or any other app. I've checked all the settings, made sure the volume is on, but it doesn't play. It won't beep for notifications like email when that function is turned on. I could use any help or advice.
    Max
    Max is offline
    455
    58 times
    Feb 2010
    San Francisco, CA
    345
    Double click so the multitasking tray opens on the bottom, swipe all the way to the left and check the volume rocker there.
    Also go into general settings and make sure the setting for the switch above the psychical volum buttons aren't set to mute and that it's off..
    http://www.ipadforums.net/signaturepics/sigpic455_4.gif
    44769
    Winston-salem
    5
    I have done both. Sound won't work with apps except for audio on YouTube videos and iPod app. It won't even play on the CNN apps videos.
    116 times
    15,249
    I've had this problem myself and this is what fixed it...
    44769
    Winston-salem
    5
    I performed both of those a couple of times and sound won't play with any game app. It will only play for YouTube or the iPod. It won't give me email alerts either. Not sure what to do next.
    116 times
    15,249
    Quote Originally Posted by OllieandMoses View Post
    How have you got 'Settings', 'General', 'Sounds' set up? You can turn various sounds on and off there.
    44769
    Winston-salem
    5
    All are clicked on and the volume is turned all the way up. All apps also have their sound options set to on.
    42714
    95
    I've had a couple of times where my Time Warner app had no sound. What has fixed it is to go into Settings, General, and change the Side Switch assignment from Lock Rotation to Mute. Then I slide the Side Switch to turn off Mute. For whatever reason, the sound returns. I can then change the setting to lock rotation, and the sound still works.
    44769
    Winston-salem
    5
    Quote Originally Posted by Mattmilw
    Dude, thanks. This was the fix. Awesome!
    vinayrxz likes this.
    42714
    95
    I had a feeling that might do it. Glad it's working.
  1. Wi-Fi only w/o 3G iPad2 ... better sound
    By madhatter61 in forum iPad 2 Forum
    Last Post: 03-18-2011, 09:00 AM
  2. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  3. No sound??
    By Rex126 in forum iPad Help
    Last Post: 03-04-2011, 12:08 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
ipad apps won't play sound
ipad apps wont play sound
ipad won't play sound
ipad won't play sound in apps
ipad wont play sound
ipad wont play sound in apps
my ipad apps wont play sound
my ipad won't play sound
my ipad won't play sounds
my ipad wont play sound
my ipad wont play sound on apps
why won't my ipad play sound
