Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Like Tree1Likes
Thread: Help with sound
  1. #11
    138799
    Dec 2011
    Florida
    iPad sound will not work with games
    Quote Originally Posted by Mattmilw View Post
    I've had a couple of times where my Time Warner app had no sound. What has fixed it is to go into Settings, General, and change the Side Switch assignment from Lock Rotation to Mute. Then I slide the Side Switch to turn off Mute. For whatever reason, the sound returns. I can then change the setting to lock rotation, and the sound still works.
    I have done everything in this series of comments ... and nothing is making the sounds for the games work. I am at a loss at what to do next!
    UPDATE:
    Just solved it via another post in the forum... above the volume switch on the side of the iPad is another little button that puts the iPad in MUTE mode ... just like on your iPhone ... switch that back and your volume is ON ... YAY!
  3. #12
    173668
    Mar 2012
    TX
    Thanks! I have had the original Ipad for over a year and you just fixed my problem. I had no idea I had it on mute, I guess I
    should read all the instruction book.
  4. #13
    205051
    May 2012
    india, bangalore
    dude....even it worked for me....awesome...i was really fed up with those apps with out sound....its a simple thing but amazing....
    thank you very much
  5. #14
    220981
    Jun 2012
    Carbondale, PA
    Quote Originally Posted by txlegz View Post
    UPDATE:
    I had the same problem...thanks.
  6. #15
    138164
    2 times
    Dec 2011
    USA
    133
    Glad you figured it out!
  7. #16
    264829
    Dec 2012
    Alberta, Canada
    Thanks!
  1. Wi-Fi only w/o 3G iPad2 ... better sound
    By madhatter61 in forum iPad 2 Forum
    Last Post: 03-18-2011, 09:00 AM
  2. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  3. No sound??
    By Rex126 in forum iPad Help
    Last Post: 03-04-2011, 12:08 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
ipad apps won't play sound
ipad apps wont play sound
ipad won't play sound
ipad won't play sound in apps
ipad wont play sound
ipad wont play sound in apps
my ipad apps wont play sound
my ipad won't play sound
my ipad won't play sounds
my ipad wont play sound
my ipad wont play sound on apps
why won't my ipad play sound
