Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    44747
    Glasgow
    12
    Ipad 2 Bluetooth Headphone Problems
    Hi there,
    I have a pair of Sennheiser MM400 Bluetooth headphones. They work with my iPhone 4 a treat over Bluetooth but when I use them with my iPad 2 the sound cuts out every few minutes. I simply have to press the main action button on the side of the headphones and the sound comes on again but it's a touch irritating.
    This sound cutting out is not consistent either. So far I have observed the following.
    On iPod - if screen off, cuts out every few mins as described. If on is OK.
    On some games (plants vs zombie's for example) - cuts out even if screen on.
    On BBC iplayer the program will sometimes randomly stop. Pressing action button on phones starts it again.
    It seems like a software problem of some sort so I am hoping it is fixed in an update sometime. Is there a known issue with ipad2 and Bluetooth headphones?
    Overall my iPad 2 rocks apart from this niggling issue.
    Thanks in advance for any help you can offer.
    116 times
    15,249
    OK - before we get down to more complex solutions, let's try the simple ones first...
    If these don't help - get back to us and we'll move on to some other possibilities...
    44747
    Glasgow
    12
    Hi Tim - gave both your suggestions a try then tested extensively yesterday. While I'd say the problem has lessened it's not eliminated. It was not cutting out nearly as often but appeared more random with sound sometimes flowing uninterrupted for 20 minutes then other times cutting out a few times a song.
    I'll keep playing around and see if I can identify any more patterns that help identify the cause.
    Cheers.
    116 times
    15,249
    Let us know how you get on and, if the problem persists, we'll see if we can come up with some further suggestions.
    I can't recall - have you tried unpairing the headphones and then pairing them again?
    44747
    Glasgow
    12
    Yeah - tried unpairing but no difference.
    Still beffuzled tbh. Got almost an hr with no pauses yesterday afternoon and no rhyme nor reason for it?
    I'll be in touch
    9123
    Jul 2010
    Montreal
    12
    Mine does this as well...different headphones though
    I have the same cutting out sound on my Nokia BH-905 bluetooth headphones.
    Never had this happen on the original ipad. I hope this gets fixed soon.
    44747
    Glasgow
    12
    Sorry to hear you have the same prob mtltdi but glad I have someone to share in the sorrow
    Since re-pairing and rebooting it's been noticeably better and much more bearable so I suggest doing that till a fix is found. Just a bug I am guessing?
    53614
    May 2011
    Albany, New York
    Having the same issue myself with Motorola S9 Bluetooth headphones - audio playback skips intermittently using the IPod app on IPad 2 - definitely annoying. Using standard headphone results in no audio skipping. Reboot / Re-Pair to no avail.
    52836
    May 2011
    UK
    8
    Quote Originally Posted by mtltdi View Post
    Have you fixed the issue, if yes add me as a friend so i can fix my nokia headphone, same problem.
    38177
    19
    Just a data point, I'm using the Motorola S305 BT headset with my iPad 2 and it works flawlessly (in terms of keeping a solid, continuous connection). They're not loud enough, and there's a little more hiss than I'd like, but the signal is solid.
    So it's not a universal problem.
  1. Headphone jack broken and stuck in ipad
    By DrDave in forum iPad Help
    Last Post: 09-30-2012, 04:37 AM
  2. Headphone port
    By accordlayingkit in forum iPad General Discussions
    Last Post: 01-26-2011, 04:41 PM
  3. Headphone jack on Ipad
    By marcoangels in forum iPad General Discussions
    Last Post: 12-25-2010, 07:27 PM
  4. Headphone problems
    By Randolfe in forum New Member Introductions - Site Assistance
    Last Post: 11-10-2010, 04:14 PM
  5. Headphone problems
    By Dandaman11223344 in forum iPad General Discussions
    Last Post: 10-27-2010, 12:09 PM
bluetooth headphones skipping ipad
bluetooth ipad sound cuts out
headphones are nor loud enough ipad
i cannot hear udio on my ipad bluetooth earphone
ipad 2 bluetooth pair no sound
ipad 2 bluetooth volume problem
ipad 2 headphone problem
ipad 2 nokia bluetooth headphone
ipad bluetooth interuptions
ipad bluetooth sennheiser headphone
sennhieser bluetooth problems with ipad
sound to bluetooth headphones
