Problems with Safari
This is a discussion on Problems with Safari within the iPad Help forums, part of the Apple iPad Discussions category; Safari has a problem for a while, which it would lag while loading a page, then go to the home page (the one where all ...
Safari has a problem for a while, which it would lag while loading a page, then go to the home page (the one where all you apps are). It usually was just a minor annoyance (as the pages would have to reload if you entered them, and also you have to constantly click safari). But just now, when I got kicked out, all my pages were gone. Then there was no history recorded even though I had some of the pages for over an hour. Can someone enlighten me whats going on? And also on the problem of safari kicking me out? Its very exasperating.
04-06-2011 09:11 PM
Originally Posted by
Lolstouall
problem
i just bought my i pad 2 one day ago but it sometimes just kick me back to the home screen and just now suddenly restart any solution to help?
- You may not post replies
- You may not edit your posts
Forum Rules
By nealpa3 in forum iPad Help
Last Post: 04-10-2013, 10:04 PM
By WAM in forum iPad Help
Last Post: 08-16-2011, 10:45 PM
By Dansandberg in forum iPad Help
Last Post: 03-15-2011, 01:00 PM
By devis in forum iPad General Discussions
Last Post: 10-05-2010, 09:30 PM
By MikesTooLz in forum Off-Topic
Last Post: 08-01-2010, 09:00 AM
i pad problems with safari
ipad keeps kicking me out of safari
ipad kicking me off safari
ipad problems with safari
ipad safari problems
ipad safari troubleshooting
ipad troubleshooting safari
my ipad keeps kicking me out of safari
safari troubleshooting ipad
troubleshooting ipad safari
why does my ipad keep kicking me out of safari
why does my ipad kick me out of safari
