iPad (original) dropped Charter email HELP PLEASE
This is a discussion on iPad (original) dropped Charter email HELP PLEASE within the iPad Help forums, part of the Apple iPad Discussions category; I've owned the original 16GB iPad for about two weeks. For the first 7 or 8 days I was excited by the very rapid access ...
Results 1 to 7 of 7
    44084
    Washington state
    I've owned the original 16GB iPad for about two weeks. For the first 7 or 8 days I was excited by the very rapid access to my Charter email and the fact that the iPad allowed me to read and delete while preserving the messages on the server for subsequent download and reply (iPad isn't as easy as a real keyboard). Then, the iPad refused to contact Charter and I've tried every combination shown in the various problem responses that Google has provided and I've tried to match the still-working settings on my laptop and desktop. All three (LT, DT a & iPad) are on a wireless home network. The iPad accesses the internet without problem. It's the doggone SMTP, etc. settings that are driving me crazy for about a week now. "mail.charter.net"? "mobile.charter.net"? "smtp.charter.net"? POP mail servers, SMTP servers, etc. ???? I can't believe that I set this all up initially with no problem, lost it all with no (known) change to setup and can't recover despite trial and error interchanges of every (?) conceivable setting. I've tried to reproduce all suggested fixes to no avail. Did Charter make a significant change (like their new email program). Can anyone help? I would be very grateful for any suggestions!!!!
    Ken Jordan
    42649
    Cocoa Beach, FL
    10
    Switch to google. I never understand why anyone uses the crappy email provided by their ISP's. With goggle you can switch providers and always keep your email address the same. Switch when using an ISP and you are going to lose it. Go ahead and make the change. If you have a forwarding option just point it to your gmail address until everyone you contact gets your new address.
    119 times
    15,248
    Quote Originally Posted by Ken1934 View Post
    Ken Jordan
    We're here to help!!!!
    OK - before we get into the complicated stuff, let's try a couple of very simple things first that - in about 50% of the cases - solve the problem....
    OK - it would be great if this fixed your problem but, problems being what they are, usually don't. Give it a try and get back to us if the problem is still there.
    44084
    Washington state
    Smile Thanks So Much!!!
    That was easy! The shut down of the iPad did the trick. Your paragraph presented so much new info (turning off periodically, double-clicks and hold-downs, etc.) Is there someplace one can go to find a list of "tricks"? While i have your attention, is there a simple explanation of setting up VPN and do I really need VPN just to access email at a hotel or other public place. I have no confidential content on my iPad (at least not yet). Once again, thanks for the very helpful tip.
    Ken
    119 times
    15,248
    Ken
    I don't really know of any place all this information is located - other than the iPad manual (and iPad Forum, of course - there's a thread on Tips and Tricks)
    Apple - Support - Manuals
    I doubt whether a VPN is necessary - in any case, does your email service provider support the use of VPN? If not, it's not clear to me how you'd do this.
    Have fun
    59982
    May 2011
    Midwest US
    5
    charter email
    I have the same problem, Ken. I am 75 and not a computer quick study. My son synched my new Ipad2 to desk top. Mail worked fine for a while. Now all I can get on IPad is "cannot get mail. The connection to the server failed". I can't even get Charter webmail via Safari. Ken from Wisconsin
    119 times
    15,248
    Quote Originally Posted by kencook35 View Post
    Did you try the reset option in the posts above? It cures a whole load of unexplained problems.
    Can you get any other websites using Safari? If you can't get Charter webmail or your mail via the iPad's Mail app, then it's unlikely to be a settings issue. So let us know if you can see any other websites - i.e. to be sure that your Internet connection is working OK.
  1. Have you ever dropped your iPad?
    Last Post: 06-08-2012, 02:24 PM
  2. Has anyone dropped their iPad 2
    By EIGHTYTHREE in forum iPad General Discussions
    Last Post: 12-21-2011, 05:52 AM
  3. Ouch! Dropped the iPad
    By rocshaus in forum iPad General Discussions
    Last Post: 03-29-2011, 06:36 PM
  4. woops dropped my iPad on cement
    By Temp40 in forum iPad General Discussions
    Last Post: 08-21-2010, 08:07 AM
  5. Have you ever dropped your ipad? Bumped it?
    Last Post: 06-24-2010, 09:00 AM
can't access charter webmail on ipad
charter email on ipad
charter email safari
how do i delete my email address through charter.net on ipad
how to use charter email on ipad
ipad email charter
mobile.charter.net problems
the mail server mobile.charter.net is not responding
Tags for this Thread
