iPad 2 running very slow
This is a discussion on iPad 2 running very slow within the iPad Help forums, part of the Apple iPad Discussions category; Hi I've had my iPad 2 3G 32gb now since launch in the uk and when using it at home on the wifi network the ...
Results 1 to 7 of 7
    42198
    London
    Hi I've had my iPad 2 3G 32gb now since launch in the uk and when using it at home on the wifi network the performance is very slow:
    Apps take forever to download
    Web pages
    You tube videos
    Streaming content etc
    My iPhone on the same wifi connection works great.
    I did a ping test and compared the two of them and the iPad did badly
    iPhone 3GS - ping 51ms, dload 6.11mps upload 0.31mbps
    iPad 2 - ping 54ms, dload 1.11mbps, upload 1.02 Mbps
    The above is the average over 3 tests.
    How can there be such a difference when the iPad 2 should be far more powerful than the iPhone.
    Anyone have any advice? - this is my second iPad 2 and I don't want to bring it back to get another one. When I went to the apple store with the first one they never even looked at the iPad or tried to offer advice, they just saidmthey would replace it.
    Michael
    116 times
    15,249
    OK - this probably won't help but it fixes a whole load of problems...and it's easy to try....
    If this doesn't work - or, more likely, you've already tried it, get back to us and we'll try some more 'difficult' solutions...
    42198
    London
    Hi tim,
    Thanks for the post. I've tried what you have suggested and the problem still exists.
    I tested my iPad on the wifi network at work and it worked great I did a ping test and the results came back in excess of 6mps.
    I then called my broadband provider O2 and they suggested changing the channel that the broadband signal was received on as if everyone in your area is on the same channel by default when initially setting up their routers it can cause congestion and slow the internet speed. I said it probably wouldn't work as my iPhone works fine.
    Anyway they changed the channel a few times and the ping test improved to about 3 Mbps download but that still wasn't good enough as the iPhone 3GS is double that. The technical guy at O2 agreed and said the router I have must not be compatible with the wifi chip in the ipad2 and that they would send me out a new different router a newer model with the latest firmware and see how that goes. Should be with me by Tuesday next week so will let you know the results.
    Michael
    61900
    Jun 2011
    london
    Question
    I have exactly the same problem on ipad2. have updated software. also on o2. very sluggish. did you manage to fix it? partic bad with bbc iplayer. please help...
    42198
    London
    Westhamstead you need to call O2 and request a new router be sent out. As soon as I got a new one with the latest firmware iPad browsing & streaming works great.
    Good luck
    171363
    Mar 2012
    philippines
    hi guys! im experiencing the same thing. everything was running smoothly until recently my ipad2 slowed down. i have not changed ISP, i have a laptop and internet is running smoothly. so does this problem mean router compatibility issues with our ipads?
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by funkykarma13 View Post
    If your issue started recently and was not always like this. That makes it sound more like an interference issue. One of your neighbors might have gotten a new wifi router that is using the same channel as yours and causing interference. Try changing your router to another channel to see if the issue clears up.
  1. Slow ipad??? please help before i trash it
    By donbrasco in forum iPad Help
    Last Post: 05-27-2011, 08:35 PM
  2. First post / slow iPad
    By KJSmitty in forum iPad Help
    Last Post: 03-18-2011, 10:09 AM
  3. iPad Safari - Really slow
    By DaveSmith in forum iPad Help
    Last Post: 10-12-2010, 08:19 AM
  4. Ipad syncing slow
    By psmoore in forum iPad General Discussions
    Last Post: 07-02-2010, 02:17 PM
  5. iPad app sales off to a slow start?
    By JohnnyApple in forum Apple iPad News
    Last Post: 04-18-2010, 03:34 AM
ipad 2 is slow
ipad 2 running slow
ipad 2 slow
ipad 2 slow wifi
ipad2 slow
my ipad 2 is running slow
my ipad 2 is slow
slow ipad 2
why is my ipad 2 running slow
why is my ipad 2 slow
why is my ipad 2 so slow
why is my ipad so slow
