update problem
This is a discussion on update problem within the iPad Help forums, part of the Apple iPad Discussions category; Hi everyone, I have a problem updating my ipad 2 from 4.3 to 4.3.1 After finishing downloading the file,it says"there was a problem downloading the ...
Results 1 to 10 of 10
Thread: update problem
    43824
    czsysz_1@hotmail.com
    update problem
    Hi everyone,
    After finishing downloading the file,it says"there was a problem downloading the software for the ipad ,the network connection timed out. Make sure your network settings are correct and your network connection is active, or try again later".
    can anyone help me to solve the problem?? T-T
    Thanks in advance.
    119 times
    15,248
    Quote Originally Posted by czsysz View Post
    Hi everyone,
    Thanks in advance.
    Several members have had this problem - and got the exact same message as you. What state is your iPad in now? Did the upgrade, in fact, take place? Is it still working OK? Check to see what version of iOS the iPad is reporting in the 'Settings', 'General', 'About'
    39481
    5 times
    447
    I got this message for my iPhone and iPod touch. You simply need to start it again and it should go.
    The second time through it doesn't need to re download the entire file.
    It happens when I was doing a restore. iTunes times out during the update or restore process if the download takes to long.
    64GB 3G White iPad
    39584
    Kansas
    15
    Mine took a while, but it did update just fine. (took about 30+ mins).
    YGB
    YGB is offline
    54488
    May 2011
    I had this problem and it was driving me nuts.
    The IOS 4.3 download would apparently complete and then I'd get the "network connection timed out" error, whether I was downloading and updating or simply downloading.
    Having trawled the web for answers, I finally succeeded when I -
    - connected the iPad to a USB port at the rear of my (Windows XP Dell) PC rather than the front.
    - removed a Bluetooth USB dongle from the PC
    - disabled Kaspersky Internet Security (2011) and
    - did a download only
    I then kicked off the install from iTunes and everything worked out. I can't be sure which action fixed the problem but I suspect it was disabling Internet security.
    I hope this helps someone avoid the some of the frustration I was having....
    Geoff
    Melbourne
    iPad Guru
    30446
    12 times
    3,196
    @YGB
    Kaspersky tends to block iTunes, so when iTunes tries to download the update, it times out. So disabling it temporarily was the correct choice.
    58222
    May 2011
    hawaii
    29
    man! i wish i had checked here first; was so frustrated when i ran into this problem; couldn't figure out why it was happening; read this thread, disabled kaspersky and boom, the download goes fine. thanks!
    35386
    Feb 2011
    London
    102
    Quote Originally Posted by airhead
    Yep and on McAfee disable Fire wall first, then its all good.
    S
    100487
    Sep 2011
    Johannesburg
    Hi All, I am new to this, so please bare with me.
    can anyone help me to solve the problem?? i'm using an apple macbook i have also tried this on a windows pc.
    kind regards
    58222
    May 2011
    hawaii
    29
    did you read the post above yours? in my case, i simply needed to disable Kaspersky while the download takes place. i don't know what kind of anti-virus program you have or firewall, etc. that may be the problem... good luck and please post your results.
  1. Download ipad update problem
    By Luketaytay in forum iPad Help
    Last Post: 08-10-2011, 12:06 PM
  2. Hello from China! I have an update problem
    By Shanghaimike in forum New Member Introductions - Site Assistance
    Last Post: 04-06-2011, 12:22 AM
  3. Replies: 8
    Last Post: 12-04-2010, 04:14 PM
  4. Replies: 4
    Last Post: 09-12-2010, 07:22 PM
  5. Cydia update problem
    By Luketaytay in forum iPad Hacking
    Last Post: 08-17-2010, 06:35 PM
ipad update problems
make sure your network settings are correct and your network connection is active
make sure your network settings are correct and your network connection is active ipad restore error
network settings ipad update
network settings to update ipad
problem downloading software for the ipad, the network was reset
update of i-pad
