University site pdf problem
This is a discussion on University site pdf problem within the iPad Help forums, part of the Apple iPad Discussions category; Hello all! I have tried doing a search and have found this problem has been posted however I feel my issue is unique. Soo here ...
Results 1 to 9 of 9
    43724
    Columbus OH
    Exclamation University site pdf problem
    Hello all!
    Soo here it goes
    My university(the ohio state university) has a webiste where notes and readings can be viewed for class. I believe it is similar to " blackboard" however I have never used that site. My school site does NOT allow me to downdload pdf files. It does however have an "in site" document reader to view the pdfs. Once I tap to open a pdf file, this viewer only shows the first page and a little of the second of a given file. It appears to just cutoff the document at some point. When I hold down on the file link the option to "open java script" appears. I have heard about an app called good reader but I am not sure if it will fix my problems.
    Thank you very much!
    -paul
    iPad Guru
    30446
    11 times
    3,197
    Goodreader most likely won't be of any help in that situation, as the PDF file never leaves the server as a whole. But if flash is involved, you might want to try iswifter as a browser.
    43724
    Columbus OH
    Iswifter didnt quite work. When I opened a file it prompted me to select something to open it with. Which didnt let me actually open thefilewith something else. After the first file I opened the browser never prompted me again.
    What other browsers or ideas do you have? Thanks!
    579 times
    Dayton, WA
    13,188
    Have you tried scrolling the document on the site? You can often scroll stuff that appears in windows or frame bars by using two fingers instead of one and swiping inside the frame.
    43724
    Columbus OH
    No luck with two finger scroll either
    43724
    Columbus OH
    to me this problem makes my ipad sort of useless. Anyone have any other ideas?
    579 times
    Dayton, WA
    13,188
    Have you talked to your university IT staff to see if they have an alternate method, or know of an app you can use? You are probably not the first iPad user they've had to deal with. It's possible a solution is in place, but poorly advertised.
    Even if they don't, every iPad user who asks adds another reason for them to start working on a solution. At some point they're going to realize that tablets are here, not going away, and need support.
    108661
    Oct 2011
    I had this exact issue with my Uni's Blackboard website.
    Luckily there is a solution, there is an app called OpenItApp - here is the link bit.ly/n2uTF4 (the forums won't let me post a live link). It works around the issues with iPad and blackboard and extracts the document so you can see the whole thing properly. Then you can open it in other apps.
    This app automatically goes to the website for Monash University in Australia but if you enter your website manually it should work.
    Good luck!
    88343
    25 times
    Aug 2011
    New York City
    422
    Quote Originally Posted by mjb389
    Good luck!
    Can you also upload to Blackboard from your iPad with that app? I've tried 6 different browsers with no success and my institution has no plans of becoming a participating member of the mobile Blackboard community right now.
    Transferring files to Mail before downloading and then uploading them to Blackboard on a computer has become so unwieldy that I've now started experimenting with transferring files to iWorks.com before downloading and then uploading them to Blackboard from a school computer to the single online section of a course I teach. It removes the hassle of having to weed through all my mail for files related to my online course but I'm definitely open to a less cumbersome solution.
  1. iPad University Use
    By Yulia in forum iPad General Discussions
    Last Post: 03-07-2011, 06:05 PM
  2. Ready for university
    By ViperESF in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 01-30-2011, 06:09 PM
  3. Hello. This site is great. Have question, not problem!
    By chowdown in forum New Member Introductions - Site Assistance
    Last Post: 12-12-2010, 07:00 PM
  4. Splashtop on University Network
    By steve989 in forum iPad Help
    Last Post: 10-25-2010, 01:45 PM
  5. iPad for university?
    By Vivrichards in forum New Member Introductions - Site Assistance
    Last Post: 03-09-2010, 01:46 PM
blackboard pdf ipad
download pdf blackboard ipad
how open pdf in blackboard on ipad
how to download pdf on ipad from blackboard
how to open a pdf on ipad from blackboard
how to open the notes from blackboard in my ipad
how to scroll embedded pdf on ipad
how to view blackboard pdfs on ipad
ipad blackboard pdf
ipad only shows first page pdf
pdf only open first page ipad
why pdfs get cut off on ipad
