Connecting a USB device
This is a discussion on Connecting a USB device within the iPad Help forums, part of the Apple iPad Discussions category; Hi all. I have researched extensively on the web and cannot find an answer can anyone help? I am looking to use keynote with my ...
Results 1 to 3 of 3
    40903
    I am looking to use keynote with my Kensington USB remote which allows u to change slides remotely. Does anyone know if the apple camera connection kit enables you to connect such a device using it's USB facility?
    I know you can use an app on your iPod touch to control slides but this I believe uses wifi which is not always available where I am.
    Please can anyone help?
    Banned
    10565
    16 times
    Jul 2010
    Va
    1,251
    Good question. As apple has reduced the voltage output to the connector slot for Camera connection kit. So not sure if it'll accept that USB remote. Hopefully someone else will chime in soon on that issue. You always just get the kit, try it out, then if it doesn't work, just return it to the store. That's if a more exact answer doesn't come soon enough.
    Sent From IPF app, if u need to know about the wonders of Jailbrake, inbox me!
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    that is one of those things you will just have to try and find out.
    take it into the apple store and ask them to get one from the back to make sure it works before purchasing.
  1. iTunes: How to change sync settings without connecting device?
    By xlar54 in forum iPad General Discussions
    Last Post: 06-19-2012, 12:24 AM
  2. Connecting to Verizon
    By Jchac in forum iPad 2 Forum
    Last Post: 03-14-2011, 07:21 PM
  3. Connecting an iPad to tv
    By Kwillson in forum iPad Help
    Last Post: 11-07-2010, 01:55 PM
attach usb devices to my ipad2
can i connect a usb device to an ipad
can i connect a usb device to my ipad2?
can i hook up usb divice to my ipad
connect usb device
how can i connect a usb device to ipad2
how can i connect an ipad to a usb device
how to connect a usb divice to ipad
how to connect an usb to ipad2
how to connect usb device to ipad
how to use usb devices with ipad
keynote remote
