MP4 movie won't sync to Ipad? Help
This is a discussion on MP4 movie won't sync to Ipad? Help within the iPad Help forums, part of the Apple iPad Discussions category; I have an HD movie in MP4 format that I want to sync to my Ipad but when I do itunes says that the Ipad ...
Results 1 to 10 of 20
    3208
    Apr 2010
    I have an HD movie in MP4 format that I want to sync to my Ipad but when I do itunes says that the Ipad doesn't support this type of file. I though the Ipad could support MP4 and H264. Is there a free converter out there I can use? I really just want some way to put this movie on without having to pay money to do so. Thanks!
  2. #2
    Supporting Vendor
    456
    Feb 2010
    Asia
    1,275
    Smile
    Quote Originally Posted by ericejs15 View Post
    Hi here you can got Handbrake witch is free and the best converter i know
    Hope that help
    Nobody is perfect and me the first
    Ipad essential accessories
  3. #3
    3208
    Apr 2010
    Thanks! I have read a few things about handbrake but i am confused about which preset to use? I see that many people just use Apple TV as the preset and it comes out fine. Is there any thing else I need to tweek for conversion? I don't care about space I'd like the best quality possible since I have the 64 GB ipad it doesn't bother me too much.
  4. #4
    iPad Ninja
    772
    Feb 2010
    Near Montréal Québec
    1,929
    Are you trying your movie from a computer sync with iTunes? Does it play on iTunes?
    Not white, not black just passionate shades of grey...
    Yuno Wataï Minh
  5. #5
    3208
    Apr 2010
    Yes it plays perfect on itunes, but when i try and sync it to ipad it says it doesnt support it. Maybe tis because the file is not the rights width for the ipad screen? I was wondering if the apple tv preset on handbrake would work for syncing it to itunes.
  6. #6
    2289
    Apr 2010
    Central PA
    25
    I don't have my iPad yet, but try selecting the movie in iTunes, then click the Advanced menu. There should be an option to create an iPad/iPhone or iPad/Apple TV version of the movie.
  7. #7
    iPad Master!
    2105
    Apr 2010
    Cologne, Germany
    523
    try playing it in Quicktime. If it works, then save the file as AppleTV or HD480 with *.m4v ending.
    I just did the same thing today with a DivX-Video.
    Most likely written on my iPad
  8. #8
    2547
    Apr 2010
    Louisville
    9
    YOU must have a HD movie ???
    is it!!!
    you have to bring the bit rate down....... so if you use mac download videora link is
    Videora Apple TV Converter Download , if you use window google a free one, I do not know
    the movie/ video needs to be 640 by 480 with 160 kbs Audio.
    i am on mac and use visual Hub for all my need and It works like a magic for my ipad
  9. #9
    3208
    Apr 2010
    Quote Originally Posted by york2 View Post
    Thanks! I never knew this was an option in itunes. It worked perfectly.Took a while to convert, but it was well worth it! Oh... and HD movies look and sound amazing on Ipad!
  10. #10
    3102
    Apr 2010
    13
    Yes, if you can sync the movies to itunes, try this option.
Sponsors
  1. Movie Converting - Handbrake - Optimal Ipad
    By iserian in forum iPad General Discussions
    Last Post: 05-12-2010, 06:54 AM
  2. How to sync iPod playlists and music to my iPad?
    By Imageman in forum iPad General Discussions
    Last Post: 04-11-2010, 09:14 PM
  3. iPad sync with MS Outlook 2007
    By joshieca in forum iPad General Discussions
    Last Post: 03-30-2010, 09:43 AM
  4. If you could only put one movie on your iPad, what would it be?
    By JohnnyApple in forum iPad General Discussions
    Last Post: 02-18-2010, 11:49 PM
can ipad play mp4
convert mp4 for ipad
convert mp4 to ipad
copy mp4 to ipad
does ipad play mp4
how to play mp4 on ipad
how to put mp4 on ipad
how to transfer mp4 to ipad
ipad mp4
ipad mp4 format
ipad play mp4
mp4 for ipad
mp4 ipad
mp4 on ipad
mp4 to ipad
mp4 won't play on ipad
mp4 wont play on ipad
play mp4 on ipad
playing mp4 on ipad
