MP4 movie won't sync to Ipad? Help
This is a discussion on MP4 movie won't sync to Ipad? Help within the iPad Help forums, part of the Apple iPad Discussions category; Free iPad Video Converter is wonderful and easy-to-use iPad Converter software which can convert all your video files including HD video to iPad video and ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
  1. #11
    18799
    Oct 2010
    China
    Free iPad Video Converter is wonderful and easy-to-use iPad Converter software which can convert all your video files including HD video to iPad video and audio files that lets you enjoy watching any video on your iPad anywhere and anytime.
  2. #12
    iPad Junkie!
    15982
    Sep 2010
    NH
    154
    Quote Originally Posted by york2 View Post
    I don't have my iPad yet, but try selecting the movie in iTunes, then click the Advanced menu. There should be an option to create an iPad/iPhone or iPad/Apple TV version of the movie.
    we learn something everyday, I never knew you could do that either, Thanks for the info that works like a charm =)
  3. #13
    21439
    Nov 2010
    I tired the quicktime to save to m4v. it actually says it cannot save with that ending. I can choose to save either as .mov or m4v.mov (both)
    Would I be doing something wrong?
    Thank you
  4. #14
    2120
    Apr 2010
    272
    Quote Originally Posted by Raffit78 View Post
    Thank you
    M4v and mov both are OK, but I think there are something wrong with the preset, if you use handbrake, I think you can choose Apple TV preset as said above. Well, for handbrake preset for iPad and iPhone, I found this article can do some help: Handbrake Presets for iPhone 4 and iPad
    live and let live.
  5. #15
    25652
    Dec 2010
    Angry Movie to ipad
    Quote Originally Posted by ericejs15 View Post
    I have an HD movie in MP4 format that I want to sync to my Ipad but when I do itunes says that the Ipad doesn't support this type of file. I though the Ipad could support MP4 and H264. Is there a free converter out there I can use? I really just want some way to put this movie on without having to pay money to do so. Thanks!
    As of January 2011, I have exactly the same experience. I have discussed the matter with at least 7 support agents - all of whom profess confusion and then turn me over to another agent. I have given jup unless someone reveals a simple strategy.
  6. #16
    Banned
    22974
    Dec 2010
    usa
    53
    How about Aneesoft Free iPad video converter which works easier than Handbrake and More precise formatting options.
    Good luck for you, susam
  7. #17
    13169
    Aug 2010
    Trinidad
    25
    Hi I converted an avi file using H.264 Encoder - and somehow it saved the file as mp4. I removed it from my Movies Library in iTunes and renamed the file to m4v in Windows Explorer. I connected my iPad to let it start syncing - and dragged the m4v file to the device in iTunes - and it shows up and plays fine on the Pad now. I hope that helps.
  8. #18
    43176
    new york
    Convert video to H264 for a try.
  9. #19
    84584
    Aug 2011
    Los Angeles, CA
    5
    Usually, iPad does import and play MP4 files. However, sometimes you will fail to transfer MP4 to iPad let alone to play MP4 on iPad or iPad2. This following will describe the reason why we fail to transfer and play MP4 on iPad and the solution on how to successfully play all kinds of MP4, HD MP4 on iPad or iPad2 at How to Play MP4 on iPad, iPad2, iPhone or iPod?
  10. #20
    128836
    Nov 2011
    Smile sync MP4 movie from Itunes to Ipad
    Make sure in the sync options in iTunes, you set the option to also sync your videos. Then just resync.
    And there are step by step articles about iPad Video Transfer on PC and Mac.
    For PC: How to transfer movies/videos from iPad to Windows
    For Mac: How to transfer music/video to iPad on Mac OS
    Hope these can do you a favor.
Sponsors
  1. If you could only put one movie on your iPad, what would it be?
    By JohnnyApple in forum iPad General Discussions
    Last Post: 04-25-2012, 07:09 AM
  2. Movie Converting - Handbrake - Optimal Ipad
    By iserian in forum iPad General Discussions
    Last Post: 05-12-2010, 05:54 AM
  3. How to sync iPod playlists and music to my iPad?
    By Imageman in forum iPad General Discussions
    Last Post: 04-11-2010, 08:14 PM
  4. iPad sync with MS Outlook 2007
    By joshieca in forum iPad General Discussions
    Last Post: 03-30-2010, 08:43 AM
can ipad play mp4
convert mp4 for ipad
convert mp4 to ipad
copy mp4 to ipad
does ipad play mp4
how to play mp4 on ipad
how to put mp4 on ipad
how to transfer mp4 to ipad
ipad mp4
ipad mp4 format
ipad play mp4
mp4 for ipad
mp4 ipad
mp4 on ipad
mp4 to ipad
mp4 won't play on ipad
mp4 wont play on ipad
play mp4 on ipad
playing mp4 on ipad
