FaceTime and wifi
This is a discussion on FaceTime and wifi within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I've had an iPad for 4 hours and I'm ready to send it back!! I am connected to wifi as I can use this ...
Results 1 to 6 of 6
    42686
    6
    FaceTime and wifi
    I am connected to wifi as I can use this forum. When I try to use FaceTime, it says I am not connected to wifi. I have updated the software and turnned it on and off. No change.
    Also I downloaded the app for these forums and it won't load either. Network error.
    I have an iPhone 4 which works a treat
    Allan
    iPad Addict
    39793
    7 times
    Oxford, MS
    1,044
    By posting this to an iPad Lover site, you seem to have concluded that all iPads have this ambiguous connection error. When it fact, there are hundreds of people here who would be willing to help had your post not began, "I've had and iPad for 4 hours, and I'm ready to send it back." You may not be aware, but iPads are indeed scarce and to have one right now is a privilege (if you notice my signature).
    In regards to your network error, I believe the server was busy, as I received the same message. In regards to face time, you might try to reset your connection to your router and LAN system. Sometimes, there are clogs in systems and they do not act as we would have them. For all other issues, another poster may oblige your concern. In the future, ask questions to receive proper answers.
    If you have tried and failed at all attempts, I would at last call Apple as they are very helpful and will send guides for future references.
    If you are truly unhappy, do send it back before you face restocking fees.
    Have a blast.
    I have to write a 7 pager!
    [COLOR="] If you don't know me by now, I will never ever ever leave Apple. [/COLOR]
    iPad Addict
    6630
    20 times
    Jun 2010
    1,189
    did you check if facetime is turn off?
    Fate is not by CHANCE but by CHOICE.
    iPad Ninja
    5787
    21 times
    Jun 2010
    2,282
    Ooops thanks for the reminder. I've had this iPad for nearly a week and I've forgotten all about face time.
    Unfortunately the whirligig of time has already brought in it's revenges on my once noble features
    579 times
    Dayton, WA
    13,187
    My, people sure are grumpy today.
    WiFi connection issues are about the hardest to trouble shoot remotely, so don't take the dearth of useful comments (mine included) as a negative reaction. It's just hard to offer good suggestions on something that complex.
    The iPad, both generations, has a history of problems with some routers. It's not super common, but can be very frustrating when encountered. Many people chose to go out and buy a newer router rather than try to figure out a good configuration for their current ones. I know, that suggestion isn't likely to make you feel better.
    So the fist thing to do is determine if that's what is going on. The easiest way to do that is try the iPad with various free wifi hotspots and see if the problem persists. If it does, and no other obvious solutions present themselves then you should probably give Apple a call. Even Apple isn't immune to the occasionally lemon. If it's does only happen on your wifi, then you have some difficult choices. New router (research to be sure you get a known to work with iPad one), or play with your router and iPad settings until you can maybe get it to work. Google searches for iPad and the router's model number may, or may not, be helpful.
    I know it is frustrating to have problems right out of the box, but give yourself little time to work things out. Nothing, even an Apple iPad, is worth raising your blood pressure.
    Oh, forgot to mention. It never hurts to try the universal computer fixer. Restart the device. Give that a try first thing.
    http://support.apple.com/kb/HT4057
    Last edited by twerppoet; 03-31-2011 at 11:11 PM. Reason: add restart link and suggestion
    42686
    6
    All
    Thanks for your help. The way I solved it was to turn off all machines and iPhones attached to the network and then turned off the iPad and wireless router. When I turned router and iPad back on it started working.
    HKWrite12 - I have developed a new app which may help you. By folding up the smart cover and biting down on it, it will allow someone to use the edge of the iPad to remove broomsticks wedged in ones butt
  1. Facetime
    By Avista in forum iPad 2 Forum
    Last Post: 01-04-2012, 03:43 PM
  2. Facetime / Video Call On Apple iPad Over 3G And Wifi
    Last Post: 09-04-2011, 12:26 PM
  3. Facetime freezing?
    By Mark4777 in forum iPad 2 Forum
    Last Post: 04-26-2011, 11:30 AM
  4. Replies: 5
    Last Post: 03-07-2011, 12:42 PM
  5. facetime! anyone know this video app?
    By sdjensen2 in forum iPad 2 Forum
    Last Post: 03-03-2011, 12:08 AM
can i face time over wifi
can i face time without wifi n ipad mini no cellular
facetime busy at this time
facetime for ipad wifi
facetime ipad busy at this time
facetime ipad to ipad wi-fi
facetime ipad wifi
ipad 2 facetime wifi
ipad mini facetime busy
ipad mini facetime without wifi
ipad wifi facetime
why does facetime say busy at this time
