Help Help Help - why do I get this message when sending a message using live.con
This is a discussion on Help Help Help - why do I get this message when sending a message using live.con within the iPad Help forums, part of the Apple iPad Discussions category; I've reset my passwords in settings several times yet every time I send this email I get the follow message " a copy has been ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    31806
    2 times
    Feb 2011
    Missouri USA
    213
    I've reset my passwords in settings several times yet every time I send this email I get the follow message " a copy has been placed in your Outbox. Sending the message content to the server failed". Then it's prompting me to click on OK.
    I am using MailShot to enter the email addressees in groups, I've never has this problem before but I have a upcoming funeral to get a Color Guard email of directions out
    Guys Please Help
    Please Support the Wounded Warrior Project
    iPod 2nd 8GB, iPod nano 6th 16GB, iPod Classic 7th 160GB, iPhone 4 x 2 16GB, iPad 1 32 GB & iPad2 32GB Blk, 1 iPad 3 32GB Wifi 4G and a iPad 3 64GB Wifi.
    116 times
    15,249
    31806
    2 times
    Feb 2011
    Missouri USA
    213
    Tim,
    I did as exactly instructed in your reply and got the same error message..............
    116 times
    15,249
    Quote Originally Posted by ThePhotog View Post
    Tim,
    Sorry to hear that. I sort of knew it wouldn't be that simple....
    Can you send other emails OK? i.e. could you send a test email to yourself? I'm asking that because I'm trying to understand whether it's something with that particular message that either the iPad or mail server doesn't like or whether it's a mail server or iPad problem - i.e. it won't send *any* email.
    A further question - I use MailShot a lot too. Have you emailed to this particular mail group before successfully? If not, I wondered whether one of the recipients in the list is incorrectly formatted - so, for example, instead of 'john_doe@hotmail.com' you accidentally typed 'john_doe&hotmail.com', which would cause the server to reject the message.
    iPad Guru
    30446
    11 times
    3,197
    Emails are usually placed in the Outbox, if the email provider settings are wrong.
    For instructions to setup hotmail properly, please follow the link:
    http://thetechjournal.com/electronic...n-iphone.xhtml
    If you can send single emails from your live account, but not group emails, then perhaps the group-send app is not working properly, or the app behaves in a way that makes it appear as if it were sending spam-emails.
    31806
    2 times
    Feb 2011
    Missouri USA
    213
    Quote Originally Posted by DontUnderstandMyIpad
    I cannot send an email to myself - I get the same error message
    31806
    2 times
    Feb 2011
    Missouri USA
    213
    Don't understand my iPad. The link you sent won't stay on the link after opening it ..
    116 times
    15,249
    Are you using gmail?
    It seems others have had the same problem in the past......
    Apple - Support - Discussions - "Sending message content to server ...
    Do you have another email account you could send from? MobileMe?
    iPad Guru
    30446
    11 times
    3,197
    Ok, then it seems as if the mail settings are wrong.
    Have you followed the above linked instructions? Even though they are for an hotmail.com account and you use live.com it should be the same, as both use the Microsoft email server. Just insert you @live.com address whenever the instructions advise to insert your @hotmail.com address.
    Edit:
    The link works fine for me in iPF, did you scroll down below all the advertisement?
    31806
    2 times
    Feb 2011
    Missouri USA
    213
    I have a live.com account. So do I set this up in other, gmail or exchange?
  1. File too big message
    By peteding in forum iPad Help
    Last Post: 10-11-2011, 11:22 AM
  2. Cellular network service message sending app!?
    By Prasius in forum iPad Apps
    Last Post: 03-07-2011, 07:33 AM
  3. Just a message
    By biobunny in forum iPad Hacking
    Last Post: 02-21-2011, 12:07 PM
  4. welcome message
    By ef38 in forum New Member Introductions - Site Assistance
    Last Post: 01-04-2011, 01:02 PM
  5. Set Message Priority
    By CoMoMacUser in forum iPad Help
    Last Post: 08-04-2010, 08:17 AM
a copy has been placed in your outbox
a copy has been placed in your outbox iphone
a copy has been placed in your outbox no password provided
a copy has been placed in your outbox. sending the message content to the server failed
a copy has been placed in your outbox. sending the message content to the server failed.
a copy has been placed in your outbox. sending the message failed because you exceeded your sending limit
a copy has been placed in your outbox. sending the message failed because you exceeded your sending limit.
exceeded sending limit ipad
iphone a copy has been placed in your outbox
iphone sending the message content to the server failed
sending the message content to the server failed iphone
