Audio Problem for some apps
This is a discussion on Audio Problem for some apps within the iPad Help forums, part of the Apple iPad Discussions category; Just encountered an unusual problem on my iPad - the audio for some apps works fine but not for other apps. Everything was fine prior ...
Results 1 to 7 of 7
    4147
    May 2010
    New Hampshire
    Just encountered an unusual problem on my iPad - the audio for some apps works fine but not for other apps. Everything was fine prior to the 4.3 upgrade and although I can't be 100% sure whether that is when the problem started it is the only significant change I have made to the iPad recently. For example NPR app audio works fine while CNN app does not. When I cannot get any audio and I try to change the audio level the on screen audio level display does not show.
    Rich
    577 times
    Dayton, WA
    13,177
    Have you restarted it recently? Weird things happen when you don't restart every once in a while.
    iPad: Turning on/off and resetting
    4147
    May 2010
    New Hampshire
    Yes - that is the first thing that I did. The oddity is why a problem with some apps and not others. Suggests a subtle software issue that impacts some apps and not others. Just wanted to see if others have experienced this!! Thanks for the suggestion!!
    116 times
    15,249
    There was a post in another thread this morning (or was it last night!) from someone with the exact same problem. I made the same suggestion as twerppoet - I’ve yet to hear back.
    4147
    May 2010
    New Hampshire
    Smile
    Solved - it was the mute button setting that was causing the problem. Even though the button was set to mute some audio streaming apps still worked while others were muted. So there still is a problem related to the function of the button but not an issue for me anymore!! Thanks for your input!!
    Rich
    iPad 3G 32G / iPhone / Dell XPS 8000 Win7
    116 times
    15,249
    Quote Originally Posted by rohlrogge View Post
    Thanks for getting back to us. I learn something new everyday here! I appreciate you telling us what the solution to the problem was.
    102960
    Sep 2011
    New Hampshire
    Thanks! Your posts and Tim's suggestion helped me solve the same problem. I had fixed the mute button but apparently needed to turn it off and then back on in order to get it to recognize the change.
  1. Problem with iTunes - No "apps" tab under my device
    By dupont2005 in forum iPad Help
    Last Post: 05-06-2011, 12:05 PM
  2. Combining apps into folders problem
    By zoron in forum iPad Help
    Last Post: 03-13-2011, 06:06 PM
  3. Audio recording apps
    By drewj_az in forum New Member Introductions - Site Assistance
    Last Post: 12-31-2010, 06:40 AM
  4. Replies: 11
    Last Post: 12-23-2010, 08:50 PM
  5. Audio streaming app
    By Patkc2000 in forum iPad Apps
    Last Post: 12-04-2010, 04:26 PM
ipad app sound not working
ipad sound not working on some apps
ipad sound problems
ipad sound works on some apps but not others
no sound on family feud app
no sound on family feud ipad
no sound on some ipad apps
some apps no sound
sound not working on some apps on ipad
sound not working on some ipad apps
sounds of some apps desapeared
