Whenever I create an event in my calendar, I choose "none" for the alert, but then the 10 minute alert always pops back on. It's driving me crazy! I don't want an alert for some of my events, so why does the 10 minute alert keep coming back?!
This is a discussion on Calendar App Alert problem within the iPad Help forums, part of the Apple iPad Discussions category; Whenever I create an event in my calendar, I choose "none" for the alert, but then the 10 minute alert always pops back on. It's ...
Are you using the native iPad calendar app or something third party appOriginally Posted by nickyvw
I'm using the native Calendar app that comes with the iPad.
OK - probably not going to help....so don't get cross....
Okay, I tried what you suggested and it didn't help. Any other suggestions? It's the strangest thing. I just don't want the alert, and when I remove the alert, it comes back. Grrr!
Are you syncing the calendar with any online service, like hotmail, AOL, MobileMe, Google, etc.?
I have a local, MobileMe, and GMail calendars in the app, and none of them do this. I'm wondering if it might be a setting on the server that keeps overriding what you do on the iPad. So, you might take a look at your default settings on the server, if this applies.
Since a restart didn't work, and if none of the above helps, there are two more things to try.
If you are syncing with a service, go to that account in Settings >> Mail, Contacts, Calendars, open the account and turn the calendar off. Let it remove you events (they should be safe on the sever), wait a bit then turn them back on.
And then there is a soft reset.
Restart and Soft Reset
iPad: Turning on/off and resetting
I know this sounds crazy, but if nothing worked, then I have a feeling that there is another calendar app that you have set the alarm on previously and that is going off. If nothing works, and if you have a video/camera, then show us what is going on by uploading it to YouTube or dropbox or something.Originally Posted by nickyvw
OK, I've not got an iPad (got iPhone 4) but had EXACTLY the same problem. Note the word HAD.
I'll take a guess that you're using the built in iOS calendar but synching with another calendar (GMail in my case).
If it happens to be GMail then do the following:
Log into your GMail account online.
This was exactly what was causing the problem and it was driving me crazy. It was only when I thought I'd try to create an event online rather than the iPhone that I found the problem.
- Choose Google Calendar at the top left of the page.
- On the left side of the displayed page select 'settings' under 'My Calendars'
- On the middle of the page you will see 'Notifications'
- You should then see your Event reminders
- Click on the blue 'Remove' next to any reminders
- Save
- Ta-da!
Creating events online created the same reminders on the phone so I knew it had to be the Gmail Calendar settings, not the iPhone calendar.
Hope this helps!
And enjoy your iPads....
A fix! Thank you.
