Results 1 to 2 of 2
    39761
    Washington, DC
    Gmail contact sync problems
    I successfully imported my gmail contacts onto my IPad, but any changes I make on the iPad don't sync with gmail. I have iTunes set up to sync, I also set up an outlook account to sync wirelessly. Neither way works for changes made on the IPad. Any suggestions would be greatly appreciated. Thanks, Hal
    624 times
    Dayton, WA
    13,315
    Turn off the iTunes syncing for GMail. When you sync with your GMail it is directly with the iPad and does not need iTunes or your computer. At least not with normal setups. I suppose it is possible to secondarily sync it through Outlook. Not recommended.
    Now, if you have been using the standard GMail account, then GMail contacts on the iPad will probably disappear. You'll need to remove or turn off the old account and add it again as an Exchange account.
    Google Mail as Exchange
    Set Up Your Apple Device for Google Sync : Google Sync (ActiveSync) - Google Mobile Help
    If you have multiple Google Calendars be sure to follow the link at the bottom. Note that when it says to visit the m.google.com/sync site you have to do that on the iPad.
    If you did not delete the old GMail account, be certain that any services you have turned on in one account are turned off in the other. Though there really is no good reason to keep both account types, unless like me you sometimes switch back and forth between them for testing purposes.
  1. Replies: 6
    Last Post: 04-22-2012, 07:37 PM
  2. Contact Sync Issues
    By shanshuprophecy in forum iPad Help
    Last Post: 01-27-2011, 06:01 AM
  3. Gmail problems on iPad. Help Please!
    By jerliz in forum iPad General Discussions
    Last Post: 11-05-2010, 09:38 PM
  4. Synching contact groups from gmail
    By Mamathornock in forum iPad FAQ
    Last Post: 10-06-2010, 06:11 PM
  5. Gmail Calendar sync btw blackberry/iPad/gmail
    By weaselnoze in forum iPad General Discussions
    Last Post: 08-05-2010, 06:26 PM
contacts from iphone not showing up in gmail
contacts not showing up iphone google sync
contacts not showing up on ipad
gmail group contacts not displaying on ipad
gmail groups not showing up on iphone
gmail sync trouble ipad
google contacts not showing up in gmail
google contacts not showing up on ipad
google contacts not showing up on iphone
ipad calendar sync problems
ipad gmail contacts not showing
ipad gmail sync problems
