Results 1 to 4 of 4
    32844
    Feb 2011
    West midlands
    Wi-fi connection times out constantly
    Hi there, this is my first ever post here, although I've been a member for quite a while. I generally just read and quietly lurk. I am finding I have a persistent problem with keeping my Wi-Fi connected to my iPad. I know that you will straight away be thinking ISP problem but this isn't the case. I don't have this problem with computers on the network just my iPad. The problem resolves itself when I turn off my iPad and turn it on again, I'm then good to go for a little while longer till it happens again. Should I have particular setting in my settings? Any help greatly appreciated. Jayne
    37987
    18
    I had to go buy a new router. I couldn't even connect...seems fine now.
    116 times
    15,249
    Quote Originally Posted by Janie215 View Post
    OK - let's try a couple of really easy things first - just in case..sorry if you've already tried these. Does this time-out occur when you're in a particular app or in all apps that use WiFi? Does this time out occur if you're doing something on the iPad that is continuously using the Internet - say downloading a big movie, app or music - i.e. does WiFi disconnect in the middle of the download or only when the iPad is not actively using the WiFi connection?
    Another member with the same problem as you suggested this
    "This has resolved many issues and worth a try.
    __________________
    Cheers
    Col
    col.bris, Brisbane Australia"
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    Mine wasn't timing out ,it just would refuse to ping my router after going to sleep and being awakened. Turning wifi off then back on would make it ping but that isn't how it worked before today.
    The above posted forget network settings worked like a charm. Thank you, I was starting to think I might have to make the 2 hour trip to my nearest Apple store.
    This forum is priceless
    Support Our Troops!!
    Sent from my iPad using Tapatalk.
    You read it correctly, iPad and Tapatalk muhahaha!
  1. Constantly 'ckecking for mail'
    By r2kays in forum iPad General Discussions
    Last Post: 02-14-2012, 11:31 PM
  2. Constantly checking for mail
    By r2kays in forum New Member Introductions - Site Assistance
    Last Post: 02-09-2011, 06:27 AM
  3. iTunes constantly asking me to log in. Why?
    By Craigfeds in forum iPad General Discussions
    Last Post: 09-20-2010, 06:10 AM
  4. iTunes is constantly asking for password, why?
    By kschueleraugsburg in forum iPad General Discussions
    Last Post: 08-21-2010, 04:59 PM
  5. Why does wifi connection slow down at times?
    By ipad987 in forum iPad General Discussions
    Last Post: 08-09-2010, 11:47 AM
ipad times out on wifi
ipad wifi timeout
ipad wifi timeout setting
ipad wireless connection timeout
why does my ipad have a connection timeout on printing
why does my ipad timeout
why does my wifi go in and out on ipad
why does wifi time out
why is my wifi connection timing out
wifi keeps timing out
wifi keeps timing out on iphone
wifi times out when downloading movies
