I Tunes problem
This is a discussion on I Tunes problem within the iPad Help forums, part of the Apple iPad Discussions category; Can't keep I Tunes open for more than a few seconds on my I Pad. Only. Happened today...
Results 1 to 6 of 6
Thread: I Tunes problem
    29526
    Dublin ireland
    I Tunes problem
    116 times
    15,249
    37158
    Arizona
    Im having a sort of similar problem..I can get the app store up no problem, but I was in the "genius" section looking at similar apps I had downloaded and that feature just quit on me. I can access the categories, top charts, etc, but the genius part gives me "cannot connect to Itunes store".
    Any suggestions? I did try the above and it didn't work.
    116 times
    15,249
    You'll probably have seen from other posts that the App Store has been having 'issues' ('problems'!) recently. Concencus seems to be that they're upgrading it - perhaps for the arrival of the iPad2 and the new apps for that machine.
    I sometimes get that 'cannot connect' message too, even though everything else works just fine. I usually leave it for a while and come back a couple of hours later and the problem has gone away.
    37158
    Arizona
    Thanks, Tim, I will just keep waiting...but I was hoping it was the store and not me..
    116 times
    15,249
    OK - if the problem persists, get back in touch and we'll suggest some more possibilities. Being in the UK, I see the UK iTunes store, so it's difficult for me to check out whether the US store is currently 'up-and-running' but, since the iPad2 is out this Friday in the US (and not for another 2 weeks in the UK) I'm assuming that any modifications or upgrades they're carrying out are being implemented in the US first of all.
  1. Rentals Movies from I tunes
    By Andr4w in forum iPad General Discussions
    Last Post: 11-22-2010, 02:49 PM
  2. How do i get my pocket tunes to work while im on the web or something
    By Drycat in forum iPad General Discussions
    Last Post: 09-21-2010, 05:02 PM
  3. Replies: 2
    Last Post: 09-03-2010, 01:27 PM
  4. iPad - Tunes in your car
    By AbsoluteMayheM in forum iPad General Discussions
    Last Post: 07-09-2010, 02:22 PM
  5. First synchronise to I-Tunes.
    By Northernstar002 in forum iPad Help
    Last Post: 06-30-2010, 12:51 PM
can't connect to itunes store top charts categories
can't get i tunes store off i pad
cannot connect to itunes store top charts
cant connet to apps store on ipa
how to turn genius off on ipad
i tune problems
ipad won't connect to app store
ipad won't connect to apple store
ipad won't open tunes
turn off genius ipad 3
viewing genres
why wont my ipad 3 go to the itunes store
