Connection issues
This is a discussion on Connection issues within the iPad Help forums, part of the Apple iPad Discussions category; Hello all, I hope that you can help with this issue. First a list of the equipment involved iPad - Wifi only. Used to run ...
Results 1 to 4 of 4
    36947
    Connection issues
    iPad - Wifi only. Used to run the Remote app.
    Apple AirPort Express
    Dlink D615R wire less router
    PC - running Windows Vista - Media Edition - wired into the router
    running iTunes
    This is what happens, using the Remote app on the iPad I reach out and touch the iTunes on the PC, then send the music down to the Airport then to the stero. All works fine. I power off the iPad (enough music for one night) next day power on the iPad, wait for the wireless connection icon to appear, then try to use the Remote app to reach iTunes. Message - Cannot find library, iTunes is still running on the PC.
    The iPad can surf the net. To regain access to the iTunes I either have to power cycle the DLink router, or the PC. Has anybody else had this problem? And if yes how did you solve it?
    116 times
    15,249
    OK - I'm sure you've tried this but....just in case.....
    36947
    Thanks but it doesn't work
    Okay, I powered off my iPad,waited 10 minutes then powered on. I connect to he internet, but cannot connect to the PC. So it seems to be a PC or router issue.
    Back to the drawing board
    116 times
    15,249
    OK - sorry to have put you through all that 'reset' and 'turn off' iPad trouble and then to get nowhere. I guess you've tried resetting the PC too, so I'm starting to run out of ideas. If you come across any more 'clues' don't hesitate to get back in contact - 1½ brains are better than one (mine is the ½ on a good day!)
  1. Tor connection issues
    By aziraphael in forum iPad Hacking
    Last Post: 10-16-2011, 01:02 AM
  2. WiFi connection issues since last update
    By jimmiem in forum iPad Help
    Last Post: 03-11-2011, 04:56 AM
  3. Replies: 4
    Last Post: 02-20-2011, 11:43 AM
  4. WiFi Connection Issues with iOS4
    By e1allen2 in forum Off-Topic
    Last Post: 09-16-2010, 11:12 PM
  5. Replies: 3
airport express connection issue ipad
dlink 615 ipad wifi issue
dlink camera app issues
dlink ipad mini connectivity problem
dlink router and ipad connection issues
dlink router problem with ipad
ipad can't connect to airport express
ipad dlink problems
ipad problrms today
ipad wireless connection trouble dlink
itunes connectivity issues dlink
wireless problems with ipad and airport express
