iPad running slowly
This is a discussion on iPad running slowly within the iPad Help forums, part of the Apple iPad Discussions category; The day out of the box for the 64gb iPad everything was lightning fast. In two weeks, the iPad is slow, sluggish, mostly in downloading ...
Results 1 to 10 of 17
    1949
    Apr 2010
    Nebraska
    18
    iPad running slowly
    In two weeks, the iPad is slow, sluggish, mostly in downloading web pages and you tube videos.
    You tube is so slow, the videos stop every three seconds to catchup.
    Netflicks is impossible to use, will not keep up.
    I have rebooted the unit, I have not reset any settings.
    My iPhone is faster, and has not slowed down like the iPad has.
    Help!
    Time for an upgrade from apple?
    Gary
    iPad 64gb wifi ~ iPhone 3GS
    1596
    334 times
    Mar 2010
    5,307
    Re: iPad running slowly
    Try doing a full restore using iTunes all your data is protected.as it will be backed up Also one of the apps that is installed main be causing problems
    Best of luck
    Sent from my iPhone using Tapatalk
    Cheers Colin,
    Brisbane Australia
    _____________________________
    iPad User Guide
    Forum Rules. Please Read.
    Hacking Section Rules
    iPad Guru
    1284
    7 times
    Mar 2010
    2,623
    Sounds like a network problem.
    Max
    Max is offline
    455
    61 times
    Feb 2010
    San Francisco, CA
    345
    Nah, a sluggish network would show on other attached wireless units. Its most likely an app thats hogging memory and doesnt tidy up after itself. Making everything else take forever, including communicating with the airportcard, ( or broadcomm, whatever they used! You get the idea!)
    Or, how much memory do you have left? Like any computer if you rack it up to the limit, it will get sluggish.
    http://www.ipadforums.net/signaturepics/sigpic455_4.gif
    2129
    Apr 2010
    Lawndale,CA
    65
    I use my 64gb everyday using some really memory hog apps and never has it showed a sign of slowing down, what type of router are you using?
    1685
    3 times
    Mar 2010
    westcoast
    800
    i never really had the problem of the unit running slow if the first place ..i just took off the about 30.gbs of music i had and put into the desktop for stowage.. i have one application that is about 5.gb that going onto the the unit and i want to make sure it ran fine before ..
    i do not really have any movies or photos on the unit so iam ok there ..my big file on the unit was the music which is about 5gb of music in which i went through and picked the songs i wanted to stay and got rid of the others onto the desktop harddirve unit and second biggest is going to the be the new application i getting 5.gb and the third biggest applications are the dvd and librarty applications ..
    iPad Master!
    2051
    4 times
    Apr 2010
    home
    1,352
    Since the slowing down is effecting downloading content, it sounds more like a network issues. You said you hadn't changed any settings, but have you checked to be sure they are all right? Re-boot the router, can help fix things even when it doesn't make since. Are you getting a strong WIFI signal when this happens?
    Anyway, just some ideas..... Good luck.
    Bremen Cole
    iPad 1st Gen 16G
    1596
    334 times
    Mar 2010
    5,307
    I miss read the problem. It does sound like a net work issue. Can you try it at a wifi hot spot to see what happens ?
    Cheers Colin,
    Brisbane Australia
    iPad User Guide
    2834
    Apr 2010
    Northern Virginia
    84
    Quote Originally Posted by col.bris View Post
    I tried mine (16gb) at Barnes and Noble on Saturday. It was PAINFULLY slow. When I use it at home with my router it is fine.
    Dana
    iPad Master!
    2051
    4 times
    Apr 2010
    home
    1,352
    Quote Originally Posted by DanaTheEwok View Post
    Dana
    More than likely NOT an iPad issue. It can only receive as fast as the network gives.
    Bremen Cole
    iPad 1st Gen 16G
  1. Apple iPad Caught Running Super Nintendo Emulator
    By IpadOne in forum iPad Hacking
    Last Post: 05-04-2010, 08:19 PM
  2. Quake II running under HTML5
    By iDan in forum iPad Games
    Last Post: 04-03-2010, 09:35 AM
  3. iPad running Windows 7 via Citrix!
    By iDan in forum Apple iPad News
    Last Post: 02-02-2010, 10:17 AM
ipad 3 running slow
ipad moving slow
ipad running slow
ipad running slowly
why does my ipad run slow
why does my ipad run slowly
why is my ipad running slow
why is my ipad running so slow
