PDFs - problem with graphics
This is a discussion on PDFs - problem with graphics within the iPad Help forums, part of the Apple iPad Discussions category; I am having trouble with graphics in PDFs. Often, they are corrupted both when I use quick view in email or when I use GoodReader. ...
Results 1 to 6 of 6
    36215
    I am having trouble with graphics in PDFs. Often, they are corrupted both when I use quick view in email or when I use GoodReader. These are PDFs which I have received by email and which appear fine on my PC.
    Is there something about email on the iPad or the settings I am using which is causing the problem? Or is it something about the PDFs themselves which is causing it? Would I get around the problem if I used something other than email to get the PDFs onto my iPad?
    It is a real shame because the graphics look great when they are ok.
    119 times
    15,248
    OK - I don't want to get your hopes up.....
    but.....
    OK - have you (a) tried iBooks? You can open them from email or GoodReader by pressing and holding until the 'Open in' menu comes up...
    if all else fails
    1522 times
    Walla Walla, WA
    15,430
    This is unusual behavior for the iPad. Most PDF files display fine. If you have a sample pdf that is safe to share, give us a link and we can check it out.
    You'll have to make two more posts before you can send a link, so take a look around the forum and have a little fun participating.
    36215
    Thanks. iBooks doesn't seem to improve things and I'm beginning to think that the problem lies in the way I create the PDFs as they are converted from Word documents. I'm going to experiment using PowerPoint and Word (I have to use a PC for work, rather than a Mac) with different Apps rather than creating my own PDF docs.
    119 times
    15,248
    As twerppoet suggests, this is definitely unusual behaviour. If you continue to have problems, then post a link to a PDF file that's giving a problem as he suggests. Presumably these files display OK on your PC using Acrobat Reader or something similar? For sure, complex formatted Word documents often have 'problems' when being read by an iPad 'Office' compatible app - such as Pages or Docs2Go - but PDF has usually been OK.
    Are you using the MS Word 'Save As' menu and then choosing PDF as the output format? I've found that does a great job usually....
    19182
    3 times
    Oct 2010
    Israel
    890
    Yep. Seems like Not all PDF Files can be read on iPAD
    I noticed few times that Magazines in PDF format came up with blank pages on the iPAD.
    Same file when you open it on a PC , every thing is fine. I wander what could be the reason. Is there a different kind of PDF reader on the iBook application ?
    I'll find a link of such a magazine and post it later.
    Any way as far as PDF goes.
    PDF versions are now defined by ISO and not Adobe. ISO 32000 is equivalent to Adobe's PDF 1.7, Adobe is not producing a PDF 1.8 Reference. Adobe is publishing a document specifying what extended features for PDF, beyond ISO 32000-1 (PDF 1.7). Documents containing extended features still carry the PDF base version number 1.7.
    Think before you Sync Since you may Sink
    The More Tweaks you have - Less Memory is left
  1. Replies: 3
    Last Post: 02-05-2011, 01:45 AM
  2. Replies: 2
    Last Post: 01-26-2011, 06:45 PM
  3. Vector Graphics?
    By Heaviside in forum iPad General Discussions
    Last Post: 01-13-2011, 01:32 PM
  4. Replies: 2
    Last Post: 01-07-2011, 08:55 PM
  5. Photo edit graphics apps
    By littlebuddha in forum iPad Apps
    Last Post: 06-25-2010, 02:15 AM
corrupted pdf on ipad
goodreader images negative
ipad 2 pdf corrupt mail
ipad corrupt pdf
ipad displaying images from pdf as negatives
lost images from pdf to ipad with goodreader
mail thegraphicissue.com
pdf does not show graphics
Tags for this Thread
