Results 1 to 2 of 2
    35261
    Feb 2011
    6
    Microsoft exchange removed from Ipad (Calendar problem)
    I have taken off Microsoft exchange account from Ipad.
    now all the emails & contacts with taken off auto as well beside calendar.
    How can i removed all my calendar events as well?
    Is there a way?
    Thanks,
    624 times
    Dayton, WA
    13,315
    There should have been an option to remove the calendars when you deleted the account. At the risk of doubling your unwanted events you could try adding and removing the account again.
    Another option is to use iTunes. I'm not sure this will work, but it's worth a try. This will probably remove all local calendar events. Calendars synced with other services like GMail should be safe.
    With your iPad connected go to iTunes and select the iPad under Devices.
    Choose the Info page from the top.
    Set your calendar to sync with a local calendar on your computer. (hopefully you have a program, Outlook or iCal, that will do this). Use a blank calendar.
    At the bottom of the page select, under Advanced, select Calendar under Replace this information on the iPad.
    Sync.
    Now go back to the Info page and turn off Calendar Sync, and sync. This may remove the calendar. If it doesn't try it gain but use the replace option in the second step as well.
    At the very least you'll end up with a blank calendar.
    Last Warning. This is mostly speculation on my part, so use with caution if there are calendar events on your iPad that you are unwilling to lose.
  1. Calendar problem
    By Turnerjpjh in forum iPad FAQ
    Last Post: 02-24-2011, 06:38 AM
  2. Replies: 2
    Last Post: 09-13-2010, 01:05 PM
  3. Replies: 5
    Last Post: 07-20-2010, 10:28 AM
  4. Replies: 6
    Last Post: 05-29-2010, 09:23 AM
  5. Setting up mail on the microsoft exchange on ipad
    By ANTHONY165 in forum iPad Help
    Last Post: 04-05-2010, 12:29 PM
delete exchange calendar ipad
delete microsoft exchange account from ipad
delete microsoft exchange account ipad
how to delete microsoft exchange account on ipad
how to transfer calendar items from ipad to exchange
ipad calendar sync issues exchange
ipad calendar sync with exchange problems
ipad delete exchange account
ipad exchange calendar blank
ipad exchange calendar issues
remove an exchange account from ipad
remove exchange account from ipad
