Problems with mail
This is a discussion on Problems with mail within the iPad Help forums, part of the Apple iPad Discussions category; I've been using GMAIL as my mail on the the IPAD and generally things are okay. However, lately I've been getting the following message "CANNOT ...
Results 1 to 9 of 9
    30971
    Israel
    9
    Problems with mail
    "CANNOT get mail The username and password is incorrect" .
    I can browse the internet and get into my gmail account via the internet
    I therefore can't understand this problem. Any suggestions
    would be greatly appreciated.
    116 times
    15,249
    577 times
    Dayton, WA
    13,177
    If that does not work, go into Settings >> Mail, Contacts, Calendars, and choose your account. Check your user name to make sure it is correct, and re-enter the password.
    If that does not work, delete the account and re-add it.
    35548
    Feb 2011
    C-Bus, OH
    255
    X2 with twerppoet. Sounds like the PW might have changed. Delete and then re-add would be my suggestion.
    Sent from my iPhone using Tapatalk
    2 x iPhone 4
    1 x 32 GB iPad 3 w/4G LTE
    30971
    Israel
    9
    Thanks to all your responses. I feel that the best solution, if the problems persists, it to do as suggested and remove this account and start all over again. I was a bit afraid to do it no knowing what damage it would do to my old mail etc., but I suppose that if nothing else succeeds that's the way to go. Thanks again for all your prompt replys.
    28359
    16
    Hey there
    Had the exact problem just now so thought I'd check in to see if anyone else was experiencing this.
    Before considering deleting the account, I intentionally set the wrong password in Settings. I was promptly told this was incorrect, so I typed the correct password.
    Refired mail and now it magically works.
    Try it first and see if it works for you.
    102663
    Sep 2011
    I tried your suggestion and it worked beautifully. I had been having the same problem with iPad
    147937
    Jan 2012
    Adelaide
    I started having this problem for the first time today. Mail has worked fine for last 5 months or so. I have tried allf the suggestions above but with no joy. I am very frustrated as I use the app every day for ail - it's a lot more user friendly than the web version. Any help gratefully received.
    577 times
    Dayton, WA
    13,177
    Sometimes servers go down for a while. Make sure you've added the account correctly and give it a bit of time. I don't know who your provider is, but this is pretty common for Yahoo. Nothing but patience will fix this.
    As a backup, most website interfaces will work with Safari. Usually the servers that handle email clients and the website interface are different, so that one can be up while the other is down.
    If it does not correct itself soon let us know who your provider is (often contains clues) and the symptoms as closely as you can describe them.
  1. Mail Problems Cannot Verify Server Message
    By SDFun in forum iPad Help
    Last Post: 04-30-2012, 10:44 PM
  2. Ipad mail keeps mail server open
    By di p in forum New Member Introductions - Site Assistance
    Last Post: 02-13-2011, 03:12 AM
  3. Mail problems
    By funkyone in forum iPad Help
    Last Post: 02-10-2011, 05:53 PM
  4. New Mail folders in iPad Mail
    By Mossi in forum iPad Help
    Last Post: 12-04-2010, 05:05 PM
  5. Tapping contacts in e-mail freezes e-mail
    By boaterbob in forum iPad Help
    Last Post: 06-21-2010, 10:33 PM
ipad cannot get mail password incorrect
ipad keeps saying cannot get mail
ipad keeps saying email password incorrect
ipad keeps saying gmail password incorrect
ipad mail app user name password
ipad mail says wrong password
ipad saying gmail password incorrect
ipad says gmail password incorrect
iphone says email password is wrong
mail app says password is wrong
why does my ipad say my email password is incorrect
yahoo mail says password is incorrect on ipad2
