How to remove drop pins
This is a discussion on drop pins within the iPad Help forums, part of the Apple iPad Discussions category; How to remove drop pins...
In the Maps app?
For the red ones you get with a search tap on the search box at the top right, then tap the X to empty it.
For any you add yourself, tap-hold on the pin until the you get a speech box, tap on the blue and white info icon, and choose remove pin.
Hey, cool. I just discovered that if you tap on the orange and white person icon instead it takes you to Google Street View.
that was cool thing to share. just yesterday i last cursed about the missing streetview. THANKS!Originally Posted by twerppoet
Yes, it is kind of sad that the actual Google Earth app doesn't have street view.Originally Posted by jamku
I use streetview all the time to check locations, parking and access etc..
Works so well with the iPad.
I agree. It is much easier to navigate on the iPad. The mouse or trackpad on the computer always feels akward
The Maps app is one of the most impressive things on the iPad. People just gape when you demo street view to them. The traffic info you can select on the Maps app is also very good and accurate - less clunky than other traffic apps.
However, I'm noticing a limit on the number of bookmarked locations it will store. I can't enter more than 8. Anyone else notice this, and is there a workaround?
I'm following up a query on another thread. Is it possible to see street view in a "travelling along" mode? I was never aware of such a feature and guess that it may be run as a Flash movie.Originally Posted by Hasty
Flash won't work on iPad?
Brought to you from my super new iPad3 - as from 03/10/12
Richard M Brown
Bromley, Kent, UK
Please read the forum rules: http://www.ipadforums.net/forum-rule...ease-read.html
I saw the other thread too and wasn't quite sure what the OP meant. To me 'travelling along' is just what you get in Street View. Did they mean that they want to be able to see Street View as they're actually travelling along the same street - that would seem kind of pointless - I mean, just look out of the window...
Or did the OP not know how to move forwards in Street View so that you could 'move along' the street that you're viewing?
