orientation propblem after upgrade of os
This is a discussion on orientation propblem after upgrade of os within the iPad Help forums, part of the Apple iPad Discussions category; there are probably some threads out there that deal with this topic - but I could figure out a search I downloaded the upgrade to ...
Results 1 to 5 of 5
    35382
    Feb 2011
    Sarnia, on, Ca
    8
    I downloaded the upgrade to the new os this week while syncing calendars and presto - lost the ability to lock the screen orientation in vertical or landscape format!!! grr - what the toggle does now is turn the speakers on and off - a useless function imo
    is there any way to undo/erase the upgrade?
    35382
    Feb 2011
    Sarnia, on, Ca
    8
    answer found
    I kept searching and sure enough - found the solution in o'rielly helps
    crazy cat lady
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,239
    When you get some time, I suggest you download a copy of the iPad User Guide. It is available for free in several different formats.
    a) As a free PDF download from the Apple website --
    Apple - Support - Manuals
    This can (and should!) be saved on your computer and your iPad.
    b) As a free iBook once you download the free iBook app from the iTunes App Store.
    c) Online using the link provided in the Safari favorites on your iPad.
    The answers to many questions, especially if this is your first Apple mobile "iDevice", can be answered by spending some quality time with this handy document.
    1541 times
    Walla Walla, WA
    15,461
    Don't know if it was worth downgrading. You can still get to the screen lock by double tapping the home button, swiping right on the multitask bar, and locking it there. You get a lot of other new features to offset the annoyance.
    4.3 will give you the option (probably) of changing the button back to a screen lock. That version upgrade is probably no more than a month or two away. Sooner if current rumors hold.
    35382
    Feb 2011
    Sarnia, on, Ca
    8
    thank you both - I found the solution and I have downloaded the manual - all good
    crazy cat lady
  1. Get Orientation Lock Switch Back On iPad 4.2 and 4.2.1
    Last Post: 07-20-2011, 04:09 PM
  2. Email not displaying until I change orientation
    By Smitman34 in forum iPad Help
    Last Post: 07-01-2011, 05:24 PM
  3. Screen orientation lock
    By Emodracer in forum iPad General Discussions
    Last Post: 01-25-2011, 07:27 PM
  4. Replies: 1
    Last Post: 12-09-2010, 04:33 PM
  5. Wallpaper orientation
    By abramsky in forum iPad Wallpapers
    Last Post: 03-29-2010, 05:10 PM
after ipad update orientation not working
how to change ipad screen orientation after upgrade
how to change orientation on ipad os 7 upgrade
ipad email locked orientation
ipad email orientation
ipad has lost orientation
ipad lost orientation
ipad mail app orientation locked
ipad mail orientation locked
refresh page on ipod orientation change
