Email problem - incoming and outgoing
This is a discussion on Email problem - incoming and outgoing within the iPad Help forums, part of the Apple iPad Discussions category; Can anyone help?
I have two email accounts on my iPad. Until last week they were working fine, now neither of them receive or send ...
Can anyone help?
I have two email accounts on my iPad. Until last week they were working fine, now neither of them receive or send email. One is a gmail account, the other is my domain account. When I open the Mail app, it shows 'Connecting...' and sometimes goes as far as 'Checking Mail...' but then it just hangs. If I try to send email, the clicking the Send button works normally but I get no indication I'm sending and the email doesn't arrive at its destination.
The problem persists whether I connect through wireless or 3G and it's not my carrier because 1. wireless and 3G are through different carriers and the iPhone on the same 3G carrier receives mail without a problem.
Any thoughts?
Michelle
02-23-2011 04:52 AM
I hope this helps. I had a similar problem with my iPad Mail a few weeks ago and this fixed the problem. But, if it doesn't, please come back and let us know - iPad Forum members love a challenge.
Tim, thank you solution #1 worked.
- You may not post replies
- You may not edit your posts
Forum Rules
By naman919 in forum iPad General Discussions
Last Post: 09-19-2012, 05:15 AM
By Fetid Ranger in forum iPad Help
Last Post: 01-07-2012, 03:52 AM
By Jen_isis in forum iPad Help
Last Post: 11-26-2011, 03:39 PM
By walterh1 in forum New Member Introductions - Site Assistance
Last Post: 12-25-2010, 04:09 PM
By Linkreincarnate in forum New Member Introductions - Site Assistance
Last Post: 06-27-2010, 12:53 AM
incoming.verizon.net is not responding
incoming.verizon.net is not responding ipad
incoming.verizon.net not responding on ipad
incoming.verizon.net not working
ipad not loading incoming mail
ipad troubleshooting email
ipad troubleshooting incoming emails
ipad verizon pop server not working
mail server pop3.live.com is not responding and my ipad
my incoming mail server on my ipad will not accept
the mail server incoming.verizon.net is not responding
why the ipad outgoing mail stops working
Tags for this Thread
