Question mark icon on images
This is a discussion on Question mark icon on images within the iPad Help forums, part of the Apple iPad Discussions category; I upgraded to the latest operating system for my iPad. Now some images in safari have a small question mark icon appearing in the middle ...
Results 1 to 5 of 5
    35154
    Feb 2011
    I upgraded to the latest operating system for my iPad. Now some images in safari have a small question mark icon appearing in the middle of them. The images load OK but the icon is annoying. How do I turn that off?
    116 times
    15,249
    I've come across something similar when an image is too big to be loaded by the iPad, but not the specific problem that you mention.
    Restart the iPad. Press *and hold* the Power button. After a couple of seconds a slider control will appear asking you to confirm that you really want to switch the iPad off (this is all you’ll be doing). Slide the control to accept. A rotating white ‘bezel’ will appear in the iPad screen as the iPad powers down (it takes a few seconds, just like it would if you were shutting down your PC). When the screen of the iPad has gone completely blank, press *and hold* the Power button for a couple of seconds until the white Apple logo appears and the iPad starts to power up. This takes several seconds, so be patient. During the power up the automatic screen orientation function is disabled, so don’t panic. A few seconds before the power up is complete, the iPad plays a little ‘jingle’ and then you’re back to the Home screen. Restart the iPad’s Safari app and see if the problem persists. Apple (and Forum members) recommend that you power down your iPad at least once a week, just as you might regularly completely switch off your PC. The normal procedure of just briefly pressing the Power button of the iPad merely puts it to ‘sleep’. Most Forum members have found that one of the two methods I’ve mentioned here cure a whole bunch of unexplained problems and are an easy first step to resolving most anything that happens on the iPad.
    Probably won't help, but it may be worth a try. It's an easy first step
    35154
    Feb 2011
    Thanks but those did not impact the issue.
    The issue can be seen if you Google "nature photographer's network" & click on their link. If you go to any of their galleries, and click on any thumbnail, the larger photo has the icon in the middle of it. I'd put the link in this post but can't since I haven't got three posts.
    Thanks for any help on this!
    116 times
    15,249
    OK - yes - I see this too. I've had pages with lots of big images display a '?' instead of the image, which is due to a lack of available system memory (RAM) but I've not seen this problem before. It's interesting, too, because if you try to copy the image to 'Photos' only the '?' copies and not the photo with the embedded '?'.
    I can only assume it *is* a system memory issue and that the new iOS takes more RAM than the previous non-multi-tasking version thus leaving less room for photos.
    Probably, like you, I've 'Googled' this problem and there seem to be a number of people reporting completely non-loading images replaced by the '?' but I've yet to find a link to someone reporting what you're seeing here.
    This is a challenge - so I'll have a more thorough look and get back to you.
    116 times
    15,249
    I have made no further progress with this. I can now see this problem on several other sites too, so clearly it's not site-specific.
    Sorry that I can't be of any more help - unless another Forum member can come up with a solution I think it's something we'll have to live with.
  1. Replies: 20
    Last Post: 01-21-2013, 12:27 AM
  2. mark
    By markmartin in forum iPad Help
    Last Post: 01-16-2011, 11:13 PM
  3. Icon placement question
    By psmoore in forum iPad General Discussions
    Last Post: 12-21-2010, 07:45 AM
  4. Mark-up and save an webpage?
    By Sviatapolk in forum iPad General Discussions
    Last Post: 09-26-2010, 07:04 AM
  5. Green check mark
    By drpep in forum iPad General Discussions
    Last Post: 07-09-2010, 10:46 AM
apple question mark images
dont get photos sent by e mail on ipad. just get a question mark
i uploaded a image and got blue question mark
iphone foto?raflar soru i?areti simgesi
my pages, numbers and keynote icons are question marks
question mark icon iphone
question mark on photos ipad
question mark photos and their meanings
when i try to open app in launchpad it has a question mark on it
why does ipad show question mark where oicture should be
why is a question mark on images
why there is question mark instead of an email icon
