Results 1 to 9 of 9
    35091
    Feb 2011
    Hamilton, Ontario
    Problems with itunes account on ipad
    Hi! Hope all is going well for everyone. My wife and I just purchased a new iPad which we're very happy with but in the course of setting up the itunes account for use in conjunction with the ipad, I've made a mistake and can't find a way to correct it. Any advice would be much appreciated. What I've done is as follows:
    I setup an original itunes store account complete with user ID, my credit card number and password. We then downloaded ibooks onto the ipad when setting it up and synced to the computer which has the itunes account.
    Things worked fine until I did two things: First, I changed the Apple User ID (to my wife's email address instead of mine as the setup is on her computer) and change the password as required as well. Secondly, I redeemed a $50.00 ibooks gift card and put it on this now revised account. The credit is there, the account is fine but the ipad still has the original account information on it. When I try to change the account information under "Settings....Store....Sign In...on the ipad, I'm advised that the new ID that I type in is already in use and not valid. The ID is my wife's email address that I used in the newly revised account.
    In short, we have an itunes account on the main computer and a different account showing up on the ipad.
    Does anyone have any suggestions on how to change the ipad account so it dovetails with its counterpart in the iTunes store?
    Any advice would be most welcome as we try and solve this problem.
    Thanks in advance.
    Bob and Louise.
    iPad Guru
    30446
    11 times
    3,197
    Have you synchronized the ipad with iTunes after changing the account ID in iTunes? This might solve the problem automatically.
    If nothing else works, you can always go to Settings->General->Reset->Reset all content and settings. And then activate the iPad again via iTunes.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Quote Originally Posted by Bob and Louise View Post
    Thanks in advance.
    Bob and Louise.
    Greetings and welcome to the forum!
    On your iPad, you can go into Settings then Store --
    From there, sign out of the account and the when you go back into the Store, you can sign in with the new account name, but do not create a new account since you already created one on your PC --
    229274
    Jul 2012
    7
    Question Still get stuck in the same account on App Store
    Device: New Ipad or Ipad 3 Celullar 64 GB
    iOS: 5.1 JB
    I have tried both and no success. I am still getting stuck in one account on App Store. Even if I log on another account, I can only buy or update Apps with the other account.
    I am thinking in restoring (reinstall iOS 5.1) and JB it again.
    Please any thread on the forum about it?
    Regards,
    Felipe
    Moderator
    235421
    148 times
    Aug 2012
    Adelaide, South Australia
    2,129
    Quote Originally Posted by carioca10 View Post
    iOS: 5.1 JB
    Regards,
    Felipe
    Unfortunately, you can no longer revert back to iOS 5.1. Once upgraded, Apple has locked the stable door.
    Regards, Andrew🐨
    ​Please come back to say whether a member's assistance solved a problem. Others may be helped by that.
    Everybody please read the forum rules--->
    iPad3 64gig black, PC Windows 8 Pro, Samsung Galaxy mobile phone, Electrolux refrigerator (cool version)
    187998
    3 times
    Apr 2012
    63
    On the ipad go to settings then iCloud and put in the account info you want to use.
    229274
    Jul 2012
    7
    Unhappy
    Quote Originally Posted by The OB View Post
    Regards, Andrew
    In fact, maybe you can with the redsnow utility tool, but there is a problem with "OTA (Over The Air) update". I have tried but failed, I probably did something wrong:
    Dev-Team Blog
    2. You DO NOT QUALIFY for iOS5-to-iOS5 restores if you got to your current 5.x via an OTA update
    • the tickets saved by Cydia, redsn0w, and TinyUmbrella do not cover OTA update ramdisk images
    • even if they did, it’s the “wrong kind” of ramdisk (you’d need to start at that earlier pre-OTA FW)
    • devices fresh from factory or refurb may fall in the “does not qualify” category (your results will vary)
    • it’s okay if you previously got to 5.x via an OTA update, as long as your current 5.x was installed via a normal iTunes restore. All that matters is how you got to your current 5.x most recently
    • redsn0w detects an OTA/normal-restore APticket mismatch very early, so if you don’t know your status there should be no harm in trying. Any device in recovery mode after such a mismatch can boot normally again just by going back to “Even More” screen from the “Restore” screen (or use “Recovery Fix” if you quit redsn0w before doing that).
    I will try again later.
    Thanks for your support.
    229274
    Jul 2012
    7
    Quote Originally Posted by Mini_mi View Post
    Mini_mi,
    Some Apps are also not funcioning well so I need really to restore, but if everything fails, I will at least try to fix the account issue by using your tip.
    Thank you.
    229274
    Jul 2012
    7
    Exclamation Thank you Apple: bye!
    Besides devaluating my Ipad 3 by discontinuing it in 7 months.
    Now they own it from me, because Apple decided I can only upgrade to iOS 6.x, and forbid me to restore to iOS 5.1.1!
    I notice that other firms like HTC use the same "OTA update" method of "jailing" you.
    What OTA means
    [Moderator edit: Removed link to external iPad-related web site. Please read our rules. Thank you.]
    Sorry, be welcome!
  1. JB ipad itunes sync problems
    By Kinghalifax in forum iPad General Discussions
    Last Post: 02-11-2011, 10:55 PM
  2. itunes problems loading on iPad
    By ipadlover55 in forum iPad Help
    Last Post: 01-29-2011, 05:37 PM
  3. Syncing an iPod and an iPad with a single iTunes account...
    By Checkpoint in forum iPad General Discussions
    Last Post: 08-24-2010, 02:24 PM
  4. ipad with 2 itunes account : impossible to install updates
    By orobin in forum International iPad Users
    Last Post: 08-16-2010, 01:07 PM
  5. IPad - setting up without ITunes account?
    By avd in forum iPad Hacking
    Last Post: 06-21-2010, 12:48 AM
cant sign into itunes account on ipad
change itunes account syncing
how to find itunes account on ipad
i synchronised my new ipad on itunes in anothers account
ipad account problem
ipad has wrong itunes account
ipad sync wrong account
ipad synced to wrong itunes account
ipad tries to log in to wrong account
sms via ipad wrong itunes id
what happens if i sync my ipad to the wrong itunes account
wrong name on itunes account
