Bluetooth connectivity
This is a discussion on Bluetooth connectivity within the iPad Help forums, part of the Apple iPad Discussions category; Ive searched and couldnt come up with an answer, so sorry if this is a repost.when i turn on the bluetooth on the ipad, it ...
Results 1 to 10 of 11
    26620
    Dec 2010
    Ohio, U.S.A.
    6
    Ive searched and couldnt come up with an answer, so sorry if this is a repost.when i turn on the bluetooth on the ipad, it just searches and searches. I have a earpiece, and my phone, both find each other, but the ipad wont find them. I want to listen to music in my earpiece, but ipad wont find it. What can i do?
    28887
    3 times
    NH
    758
    You have to have one that works with ipad, a normal bt headset wont work with it.
    Ipod 32 GB
    Not everyone has to agree with your point of views, but at some point they need to accept Them!
    iPad Guru
    1284
    7 times
    Mar 2010
    2,623
    Most single speaker bluetooth earpieces are only meant for telephone conversations and PMP devices will not allow them to work....it will work with an iPhone but not an iPad or iPod touch. There are many stereo media consumption bluetooth headphones that will work just fine.
    I use my bluetooth car stereo with my iPad sometimes and my iPhone all the time.
    26620
    Dec 2010
    Ohio, U.S.A.
    6
    Well i guess that makes sense. My bt earpiece would play music from my nokia phone, but wont with my huawei, so iguess i can uderstand it wont with the ipad, what a bummer tho. Guess i need to go find a decent pair of bt headphones. Anyone got any suggestions? Also, I hadnt thought of using the ipad in my car - the factory stereo is bt, so i will give it a shot. Thanks forum!
    iPad Enthusiast!
    31491
    Dublin, Ireland
    47
    Just make sure the ones you get are A2DP compatible, and they should work with your iPad. I got the Sennheiser MM200 headset and that works nicely, though it's not the cheapest out there.
    8596
    Jul 2010
    San Diego
    18
    One last thing to try, if you haven't already. Ensure you headset is un-paired from everything else before you try to pair it with the Ipad.
    35920
    Feb 2011
    nj
    Hi - I just found this forum and I am desperately trying to pair my blackberry 8530 bluetooth to my iPad. The iPad just searches but never connects to the blackberry. The phone shows that the iPad is a paired device but the iPad just searches and searches.. Help? thanks
    28887
    3 times
    NH
    758
    You cant do that without jail breaking ipad, As said before, there is only some headsets ipad is compatible with, but as for phones, you have to jail break ipad and buy a program in order to connect to BT phones, but even so, I dont think there is much you can do that way.
    Ipod 32 GB
    35920
    Feb 2011
    nj
    huh? i dont understand?
    119 times
    15,248
    The iPad Bluetooth has a very limited set of peripherals that it will connect to. Bluetooth keyboards are OK as are 'proper' stereo headsets and Bluetooth enabled stereo systems but not most Bluetooth cellphone earpieces.
    So the iPad will not connect via Bluetooth to PCs, Bluetooth printers, cameras with a Bluetooth interface or cellphones. Your cellphone may 'see' the iPad and vice versa, but they will not pair.
    As the previous poster intimated, there's really no (easy) way around this problem.
  1. Connectivity issues
    By TheMitz in forum iPad Help
    Last Post: 04-09-2011, 10:24 AM
  2. Connectivity
    By mnields@comcast.net in forum New Member Introductions - Site Assistance
    Last Post: 12-20-2010, 10:43 PM
  3. Bluetooth connectivity problem
    By Ecocrop in forum iPad Help
    Last Post: 08-10-2010, 09:32 PM
  4. Wi-Fi connectivity
    By Russell in forum iPad Help
    Last Post: 08-06-2010, 12:03 PM
  5. Internet Connectivity
    By Louisg in forum iPad Help
    Last Post: 06-29-2010, 01:42 AM
bluetooth blackberry 8530 to ipad
connect blackberry 8530 bluetooth to ipad 2
how to connect ipad3 to blackberry via bluetooth
how to pair ipad 2 to blackberry 8530
ipad bluetooth interface
ipad3 wont pair with bluetooth speakers
my blackberry bluetooth wont connect to the ipad
why wont my bluetooth earpiece find my ipad
