Results 1 to 5 of 5
    27198
    Dec 2010
    24
    iPad will not sync.
    I connected my iPad and it wil not sync. It connects - eg it pings and it says 'not charging' in the top right corner. iTunes starts up, but that's as far as it gets. I have uninstalled iTunes and reinstalled, but no change. iTunes does not see the iPad at all.
    Any ideas folks?
    Weird. Seems ok after I connected my iPod which synced just fine. I then connected the iPad and that worked perfectly.
    What's all that about?
    7739
    Jun 2010
    USA
    123
    Quote Originally Posted by Andygo View Post
    Any ideas folks?
    I don't have a good answer for you except software wierdness... Using a PC for many years, I just figure that things that don't make sense are going to happen in a good way and in bad ways...
    19182
    3 times
    Oct 2010
    Israel
    891
    Any ideas folks?
    What about replacing the cable. It may be broken, with some internal loose connection to one of the pins. We take for granted the Mechanical parts, but they fail too.
    Think before you Sync Since you may Sink
    The More Tweaks you have - Less Memory is left
    27198
    Dec 2010
    24
    It looks fine - its only a month or so old! And it worked straight away with my ipod.
    Its clearly a software issueas itunes took ages to appear on screen when I connected the ipad.
    20755
    7 times
    Nov 2010
    Michigan
    436
    I have a Mac book pro that would not "see" the iPad in iTunes. First, it was an old OSx ( got a message for that though). Then I found that if I had Parallels running, it would "pull" the iPad signal. Even though iTunes was on the Mac side. I had to Shut down/Stop Parallels, then Itunes could find the iPad. (iPod recognition was fine the whole time)
  1. iPad won't sync now
    By iPaddict in forum iPad Help
    Last Post: 01-14-2011, 01:32 PM
  2. How do I sync my ipad to my mac when i originally sync'd it to a PC
    By RoaHokie in forum iPad General Discussions
    Last Post: 06-30-2010, 07:48 PM
  3. Sync from PC to iPad
    By mslammers in forum iPad Help
    Last Post: 06-29-2010, 11:46 AM
  4. Replies: 1
    Last Post: 06-16-2010, 09:20 AM
  5. Sync ipad with pc
    By 300cman in forum iPad General Discussions
    Last Post: 04-29-2010, 11:10 PM
ipad is not syncing with computer
ipad not syncing
ipad not syncing to pc
ipad not syncing with computer
ipad will not sync
ipad will not sync with computer
ipad wont sync
my ipad is not syncing to my computer
my ipad will not sync
why are my ipad and iphone not syncing
why is my ipad not syncing
why will my ipad not sync
