Battery drops from 10% to 0%
This is a discussion on Battery drops from 10% to 0% within the iPad Help forums, part of the Apple iPad Discussions category; Title says it all. This only starting happening tonight. Was watching a film, the 10% warning popped up and then boom, my iPad just turned ...
Results 1 to 4 of 4
    33095
    Feb 2011
    Uk
    Title says it all.
    This only starting happening tonight. Was watching a film, the 10% warning popped up and then boom, my iPad just turned itself off and the 10% meter in the top right hand corner dropped straight to 0%.
    When i tried to turn it back on I got the message that says connect it to a charger.
    When I started charging my iPad it turned itself back on and showed 10% straight away and started to charge itself back up fine.
    I let it go to 15% and then let it go back down and then same thing-as soon as it hit the 10% warning it went straight to 0% and turned itself off.
    That 10% can be quite vital and considering the money I spent I feel like I'm owed a full battery. I have the latest update and have never had any problems at all with my iPad and have used it everyday for over 5 months now.
    Any advice or help would be greatly appreciated.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Apple advises that you let your iPad completely discharge at least once a month and let it charge back up to 100%. This really has nothing to do with the battery itself since this new generation of batteries do not have a "memory" like the old NiCd batteries, but it re-calibrates the battery level indicator.
    33095
    Feb 2011
    Uk
    the main worry is that the Ipad won't let me drain the battery. When it gets to 10% it then jumps straight to 0%. *The ipad and the battery marker has seemingly lost the ability to function at 9,8,7,6,5,4,3,2, and 1%. It also used to give a 5% left warning sign and that doesn't happen now either?
    I have fully charged it back up to 100% but if it turns itself off again at 10% then there is something fundamentally wrong with the battery i fear.
    19138
    5 times
    Oct 2010
    Frederick, MD
    327
    Quote Originally Posted by Captainconehead View Post
    If what C4 says is true (and I have no reason not to believe him - thanks C4 for the info - I didn't know that), then perhaps your metering system is out of cal and your battery is actually at 0% rather than 10%. However, I have no idea how to resolve your question outside of contacting Apple and either ask for assistance or a new iPad.
    Good luck.
    Tom
    EMP-Susceptible - with an iMac, 15" MacBook Pro/Retina, MacBook Air 11", iPod touch 2, 4, and iPad 2.
  1. 2-Year iPad Warranty Only $83.99 (includes drops & spills)
    By zman in forum iPad General Discussions
    Last Post: 03-10-2011, 10:02 PM
  2. 3G drops to E and does not return to 3G
    By rd_bhatnagar in forum New Member Introductions - Site Assistance
    Last Post: 11-29-2010, 09:25 PM
  3. Droid X Drops Signal Bars Like iPhone 4
    By 4phun in forum iPad General Discussions
    Last Post: 08-02-2010, 06:17 PM
  4. Incorrect Wep Key? Drops Network?
    By HillPad in forum iPad Help
    Last Post: 06-01-2010, 09:43 PM
  5. Wifi connection drops solution!
    By Itzxdjx in forum iPad General Discussions
    Last Post: 04-18-2010, 01:17 PM
batteries 10% ipad
battery indicator wrong
can i let the new ipad battery go to 0%
ipad 2 shuts off at 5%
ipad battery warning
ipad on 10% shuts off
ipad says fully charged at 5%
ipad shuts off 5%
ipad turns of by 10%
ipad turns off at 10%
let ipad discharge
new ipad battery warning
