Mail problems
This is a discussion on Mail problems within the iPad Help forums, part of the Apple iPad Discussions category; So far my experience with iPad has been less than good. The problem I have is getting mail. After syncing with mail accounts I was ...
Results 1 to 5 of 5
Thread: Mail problems
    33054
    Feb 2011
    Washington
    Mail problems
    So far my experience with iPad has been less than good. The problem I have is getting mail. After syncing with mail accounts I was able to receive some e-mails, but not all. I also noticed that the receiving mail icon on the lower left of the mail page never quit spinning. So after reading some internet content it was advised to delete the current mail account and re-sync the original account again after rebooting the iPad. Now when I re-sync I get a notice that the mail account cannot be re-synced because it is in use.
    What gives?
    Any help would be appreciated.
    1546 times
    Walla Walla, WA
    15,468
    Tell us what kind of mail provider you are using. That will help us come up with an answer. If you are lucky someone else uses the same provider and will have a ready answer for you.
    33054
    Feb 2011
    Washington
    I am using a local isp and it is a pop3 account.
    119 times
    15,248
    Just to clarify a little further, do you mean that you can receive some but not all email from a *single* ISP? Or do you have multiple email accounts and ISPs and mean that some work OK and others don't?
    Additionally, have you always had this problem, or is it something new?
    The 'stock' answer to fixing these problems and many other unexplained or unusual 'issues', is to completely turn the iPad off (rather than simply putting it to sleep, which is the normal way most people 'turn it off) and then restart it. This seems to cure a whole raft of 'issues'. Even Apple recommend that you do this once a week (so I've been told).
    I'm sure you know how to *completely* turn the iPad off (press *and hold* the power button). It may not work, but it's an easy first step to solving problems.
    1546 times
    Walla Walla, WA
    15,468
    For the mail in use problem, it is possible your ISP doesn't allow multiple log-ins. That is pretty common with POP accounts. This will probably time out by itself. If it doesn't try going to your mail via the web and see if you can log in that way. Log out when you are done. Then go back to the iPad and check. This might reset things.
    After that, contact your ISP and explain your problem to them. They should be able to reset your login, and provide you with the correct parameters for your account on the iPad.
    That's it for my ideas at the moment.
    Powering off/on, like Tim suggested, is also a good idea. If that does not work there is one other fix all, the soft reset. Hold down the home and power key until the Apple logo appears. This will take 10 to 15 seconds. Once it appears let go and wait for the iPad to finnish rebooting. This will take a bit longer than turning the power off then on, so be patient.
  1. Mail Problems Cannot Verify Server Message
    By SDFun in forum iPad Help
    Last Post: 04-30-2012, 10:44 PM
  2. New Mail folders in iPad Mail
    By Mossi in forum iPad Help
    Last Post: 12-04-2010, 05:05 PM
  3. Wi-Fi problems
    By iPadIt in forum iPad Help
    Last Post: 10-30-2010, 02:36 PM
  4. iOS 4.2 to 3.2.2 problems
    By Zertuz in forum iPad OS
    Last Post: 10-10-2010, 11:24 AM
  5. Tapping contacts in e-mail freezes e-mail
    By boaterbob in forum iPad Help
    Last Post: 06-21-2010, 10:33 PM
how to log off mail on ipad
how to reset mail on ipad
how tolog off email on ipad
ipad 3 sign off email
ipad mail problems
ipad new mail icon problem
log off email on ipad 2
log out of mail
rebooting ipad mail
